Constraint Equation? Multivariate calculus
In summary, this conversation discusses a calculus problem involving utility in economics, specifically the utility function for consuming goods. There are also questions about the practical meaning of partials and calculating them. The conversation then moves towards a constraint equation for Plike's consumption of cheese and marbles, where a unit of cheese costs $18 and a unit of marbles costs $12. The final part of the conversation involves finding the maximum utility given these constraints.
iamaelephant
This is a second (university) year calculus problem dealing with calculus of multiple variables.
In economics, utility is a measure of the relative satisfaction from, or desirability of, consumption of goods. A utility function u = u(a,b) gives the utility from consuming a units of a particular good and b units of another good.
The utility function for Plike Mank's consumption of c units of cheese and m units of marbles is given by u(c,m) = 2(c^2)m.
After this explanation there were some questions regarding the practical meaning of the partials, calculate the partials etc.
Part (d)
Plike's consumption of cheese and marbles is constrained by his salary. Write down a constraint equation if a unit of cheese cost $18, a unit of marbles cost $12 and he spends $216 on cheese and marbles.
Don't know
I'm not even sure what to do. I missed a couple of lectures this semester and I'm completely lost. Even if someone could point me to the relevant chapter in my textbook I'd be happy. I have never come across a constraint equation before.
Assuming I'm interpreting the question correctly: Ignore the word 'constraint', and write the equation using common sense/intuition.
The three values given are:
1. cost of a unit of cheese
2. cost of a unit of marbles
3. amount spent on cheese and marbles
So in the equation you would have 2 variables (which appear in the explanation about utility).I take it there's a part (e) to this question and so on that uses this equation as a constraint for utility?
Thanks a lot for your help, I think I nailed it but I'd really appreciate if someone could give me some feedback on my work. Here's what I got:
If marbles cost $12, cheese costs $18, total money is $216 then we set up the constraint equation
18c - 12m - 216 = 0
m = (216-18c)/12
therefore:
u(c,m) = 2(c^2)m = 2(c^2)(216-18c)/12
= 36(c^2) - 3(c^3)
Differentiating this gives
u'(c) = 72c - 9(c^2) = 0
therefore
c = 0 or 8
Using c = 8, m=6
Using these values gives a maximum utility of 4,608
Does this look correct? Sorry about not using LaTex, I'm on a university computer with a 10 min time limit. Any feedback would be mucho appreciated.
How come you have 18c - 12m and not 18c + 12m? It can help at first to add costs on one side and spendings on the other.
FAQ: Constraint Equation? Multivariate calculus
1.
What is a constraint equation in multivariate calculus?
A constraint equation in multivariate calculus is a mathematical expression that limits the values of certain variables in a system. It is used to describe relationships between variables and to define boundaries within which the variables must operate.
2.
How are constraint equations used in scientific research?
Constraint equations are commonly used in scientific research to model complex systems and analyze relationships between variables. They can help researchers understand the behavior of a system and make predictions about its future outcomes.
3.
What is the difference between a constraint equation and a regular equation?
A regular equation is used to express a relationship between variables, while a constraint equation adds restrictions or limitations to that relationship. In other words, a constraint equation narrows down the possible solutions to a regular equation.
4.
Can you give an example of a constraint equation in multivariate calculus?
An example of a constraint equation in multivariate calculus is the equation for a circle, where the distance between any point on the circle and its center is always equal to the radius of the circle. This constraint equation limits the possible values of the x and y coordinates of points on the circle.
5.
How do constraint equations impact the optimization process in multivariate calculus?
Constraint equations play a crucial role in optimization problems in multivariate calculus. They help define the boundaries within which the optimized variables must operate, making the optimization process more efficient and accurate.
