Constriction at point b, effect on flow rate before constriction
In summary, constriction at point b can greatly affect flow rate before the constriction. It can lead to an increase in flow rate due to an increase in fluid velocity, but in some cases, it may cause a decrease in flow rate if it results in turbulence or flow separation. The degree of constriction at point b can be influenced by various factors, and its location in relation to the flow path can also impact its effect on flow rate. In most cases, the effect of constriction at point b is reversible, but it may be irreversible if the constriction is permanent.
hongiddong
65
In the case of a kidney vessel from point a to point b(a-------------b), say we constrict point b and increase resistance. Would the flow rate be decreased before the constriction at b, or would the flow rate only be changed after the constriction.
Thank you Physicsforums!
The flow rate would only be changed after the constriction at point b. When the resistance is increased, it causes a decrease in flow rate by reducing the pressure gradient between points a and b.
Related to Constriction at point b, effect on flow rate before constriction
1. How does constriction at point b affect flow rate before the constriction?
Constriction at point b reduces the cross-sectional area of the flow, causing an increase in fluid velocity. According to the continuity equation, the product of velocity and cross-sectional area must remain constant. Therefore, a decrease in cross-sectional area at point b results in an increase in velocity, which leads to an increase in flow rate before the constriction.
2. What factors can influence the degree of constriction at point b?
The degree of constriction at point b can be influenced by various factors, including the shape and size of the constriction, the viscosity of the fluid, the pressure difference before and after the constriction, and the Reynolds number of the flow. Other factors such as surface roughness and temperature can also play a role in the degree of constriction.
3. Can constriction at point b cause a decrease in flow rate before the constriction?
In most cases, constriction at point b will result in an increase in flow rate before the constriction due to the continuity equation. However, if the constriction is severe enough to cause turbulence or flow separation, it can lead to a decrease in flow rate before the constriction.
4. How does the location of point b influence the effect on flow rate?
The location of point b in relation to the overall flow path can greatly influence the effect on flow rate. If point b is located near the entrance of the flow path, the constriction may have a greater impact on the flow rate. However, if point b is located further downstream, the effect on flow rate may be less significant.
5. Is the effect of constriction at point b reversible?
In most cases, the effect of constriction at point b is reversible. If the constriction is caused by a temporary obstruction, such as a blockage, removing the obstruction will restore the flow rate to its original state. However, if the constriction is permanent, such as a narrowing in a pipe, the effect on flow rate may be irreversible unless the constriction is removed or the flow path is altered.
  • Other Physics Topics
  • Classical Physics
15K
  • Aerospace Engineering
  • Mechanical Engineering
