Construct a mathematical formula
In summary, the conversation discusses the speaker's research on creating a formula to determine consumption probability in a simulation of human agents. They mention using a weighted sum but it does not give the expected output. The conversation also suggests trying different optimization functions and potentially using a neural net to overcome the limitations of linearity in the model.
adan
Hello,
I have been thinking of it for a long time, and I would appreciate suggestions from math experts.
I am working on a simulation of human agents. I want to set up a formula that defines the consumption probability (0,1), which consists of X, a value between 0 and 1, and two positive and negative integer values (0,1). The idea is to combine these variables. If positive influence is high, consumption should increase if negative influence is high, consumption should decrease. X represents personal belief without any influence.
The X and the influences variables are computed differently.
I thought of a weighted sum but that doesn't give the expected output.
Thank you!
Likes Delta2
Mathematics news on Phys.org
A weighted sum is the obvious first choice; what do you mean 'doesn't give the expected output'?
Did you set the weights manually - if so have you fully explored how your model responds to adjusting the weights?
If you have a sample 'expected output' have you tried fitting the weights using linear regression? Have you tried different optimisation functions (e.g. mean absolute error (MAE) as well as mean squared error (MSE))?
If this is still not working for you then this may be due to the inherent limitation of linearity of the model. To break through this you could consider using a neural net (a weighted sum is essentially a neural net with no hidden layers and a single neuron with a linear activation function in the output layer). However this is probably overkill for such a simple model with only 3 inputs.
Likes adan
Consider a portfolio of at least two stocks, take the consumption as the expectation value of returns, and the influences as the covariances.
Likes adan
Thank you @pbuk, for your answer!. I noticed that the weighted sum doesn't give what I expect. I don't have data but just some intuition. For example consumption = w1*X +w2 * Infpositive - w2 * infnegative.
I assume w1 should not be too small(> 0.5). I found that using the weighted sum can't enforce the positive effect. I use a negative weight w2 to achieve the negative influence.
FAQ: Construct a mathematical formula
What is a mathematical formula?
A mathematical formula is a concise way of expressing a relationship between different variables or quantities using symbols, numbers, and mathematical operations.
How do you construct a mathematical formula?
To construct a mathematical formula, you need to first identify the variables and their relationships. Then, use appropriate mathematical symbols and operations to express the relationship between the variables.
What are the key components of a mathematical formula?
The key components of a mathematical formula are variables, mathematical symbols, and operations. Variables represent unknown quantities, symbols represent mathematical operations, and operations determine the relationship between the variables.
Can a mathematical formula be used to solve real-world problems?
Yes, a mathematical formula can be used to solve real-world problems by representing the problem in terms of variables and using the formula to find the solution.
Are there different types of mathematical formulas?
Yes, there are different types of mathematical formulas such as algebraic formulas, geometric formulas, trigonometric formulas, and statistical formulas. Each type is used to solve specific types of problems.
