Construct a segment x satisfying the equation :1/x−2/a+3/(x+a)=0
  • MHB
  • Thread starter Albert1
In summary, we are discussing how to construct a segment $x$ with length $a$ that satisfies the equation $\dfrac{1}{x}-\dfrac{2}{a}+\dfrac{3}{x+a}=0$. We then discover an error in the problem and fix it by constructing a segment $y$ with length $\sqrt{ax}$. In general, constructible numbers are those that satisfy a polynomial equation with integer coefficients with degree a power of 2.
Albert1
1,221
given a segment with length $a$
(1)construct a segment $x$ satisfying the equation :$\dfrac {1}{x}-\dfrac {2}{a}+
\dfrac {3}{x+a}=0$
(2)construct a segment $y$ with length $\sqrt {ax}$
Mathematics news on Phys.org
For (1), first solve the equation for x: \(\displaystyle \frac{1}{x}- \frac{2}{a}+ \frac{3}{x+ a}= 0\). Multiply both sides by ax(x+ a). \(\displaystyle a(x+ a)- 2x(x+ a)+ 3a= -2x^2+ ax- 2ax+ a^2- 3a= -2x^- ax+ a^2= 0\). which is equivalent to \(\displaystyle 2x^2+ ax- a^2= 0\), a quadratic equation. By the quadratic formula, \(\displaystyle x= \frac{-a\pm \sqrt{a^2+ 4a^2}}{4}= \frac{-a\pm a\sqrt{5}}{4}\).
Basically, then the problem is to construct a segment of length \(\displaystyle a\sqrt{5}\). To do that, construct a segment of length 2a. At one end of that segment, construct the perpendicular to the segment and mark off length a on it. Draw the segment connecting the other two ends of those segments. This new segment is the hypotenuse of a right triangle with legs of length a and 2a so it has length [tex]\sqrt{a^2+ (2a)^2}= \sqrt{5a^2}= a\sqrt{5}[/tex].
sorry ,calculation not correct (a typo)
Oh, Pooh! Yes, there is an error (calling it a "typo" is kind).
The original equation is [tex]\frac{1}{x}- \frac{2}{a}+ \frac{3}{x+ a}= 0[/tex].
Multiplying by ax(x+ a) gives [tex]a(x+ a)- 2x(x+ a)+ 3ax= 0[/tex], not what I had before. Then [tex]ax+ a^2- 2x^2- 2ax+ 3ax= -2x^2+ 2ax+ a^2= 0[/tex]. That is a quadratic equation. By the quadratic formula [tex]\frac{-2a\pm\sqrt{4a^2+ 8a^2}}{-4}= \frac{-2a\pm\sqrt{12a^2}}{-4}= a\frac{1\pm\sqrt{3}}{2}[/tex]
$x=a(\dfrac {1+\sqrt 3}{2})$ for $x=a(\dfrac {1-\sqrt 3}{2})$ is unreasonable
now how to construct segments with length $x=a(\dfrac {1+\sqrt 3}{2})$
and $y=\sqrt {ax}$
My attempt:
From
\[\frac{1}{x}-\frac{2}{a}+\frac{3}{x+a}=0\]
We get:
\[2x^2-2ax-a^2=0\Rightarrow x = \frac{1}{2}a+\frac{\sqrt{3}}{2}a = a\cos 30^{\circ} + a \sin 30^{\circ}\]
Construction of $x$: Divide a right angle (in the 1st quadrant) into three equal angles. This is done in three small steps with a compass. Let segment $a$ ($|OA|$) be the hypotenuse with an angle of 30 degrees to the horizontal line. From point $A$ draw a vertical line to meet the $x$-axis in point $B$. The adjacent catheter of triangle $OAB$ has the length: $\frac{\sqrt{3}}{2}a$, whereas the opposing catheter has the length $\frac{1}{2}a$. Now, add a half segment $a$ to the adjacent catheter (point $A’$). Our $x$ is then |OA’|.
View attachment 7020Construction of $ax$: Mark segment $a$ on the $y$-axis (from Origo, point $A$). Mark segment $x$ on the $x$-axis (from Origo, point $X$). Then mark the unit length (point $B$) on the $y$-axis. Now connect $B$ and $X$. Draw a line through point $A$ parallel to the line through $B$ and $X$. The line cuts the $x$-axis in point $C$ at a distance $ax$ from Origo. This is easily seen from the two triangles (with equal angles):
$\frac{|OX|}{|OB|} = \frac{|OC|}{|OA|} \rightarrow \frac{x}{1}=\frac{|OC|}{a} \rightarrow |OC| = ax$.View attachment 7021
Construction of $y = \sqrt{ax}$:
Mark segment $ax$ on the $x$-axis (point $A$). Then mark the point of unit length starting from Origo to the left (point $B$). Draw the half circle with diameter $|AB|$. The half circle and the $y$-axis cross in point ($Y$). We have two triangles with equal angles: OAY and OBY. Thus, we have the relation:
\[\frac{|Y|}{1} = \frac{|OA|}{|Y|}\rightarrow |Y|^2 = |OA| \rightarrow |Y| = \sqrt{|OA|}\rightarrow y = \sqrt{ax}\]
lfdahl said:
My attempt:
From
We get:
lfdahl,thanks for participation. well done!
Just in general: The "constructible numbers" are precisely those numbers that are "algebraic of order a power of 2". That is, those numbers that satisfy a polynomial equation with integer coefficients with degree a power of 2.
FAQ: Construct a segment x satisfying the equation :1/x−2/a+3/(x+a)=0
What is a segment x?
A segment x is a line segment, which is a part of a line between two endpoints.
What is the equation 1/x−2/a+3/(x+a)=0 trying to represent?
This equation is trying to represent the relationship between the length of the line segment and the distance between two points on a number line, where x and a are variables representing those points.
How can I construct a segment x that satisfies this equation?
To construct a segment x that satisfies the equation, you will need to solve for x by manipulating the equation algebraically. Once you have a specific value for x, you can use a ruler and compass to construct the segment on a number line.
What is the significance of the constants 1, 2, and 3 in the equation?
The constants 1, 2, and 3 represent specific values in the equation that help determine the length of the segment x. They are essential in solving for x and constructing the segment.
Can this equation be used to solve for other values besides x?
Yes, this equation can be used to solve for other values, such as a or the length of the segment x, by manipulating the equation and plugging in different values for the variables.
