MHB Construct using unmarked straight edge only
  • Thread starter Thread starter caffeinemachine
    Edge
To construct a line through point P that is parallel to line AB using only an unmarked straight edge, first identify the midpoint M of AB. Draw a random line through M that intersects line AP at point X and line BP at point Y. The intersection of lines BX and AY creates point Z, which establishes that line PZ is parallel to AB. This construction effectively connects point P to the harmonic conjugate of M on line AB, which is the point at infinity. The discussion concludes with the application of Ceva's theorem to finalize the construction.
caffeinemachine
MHB
Let points $A$ and $B$ be given on the plane. The mid point of $A$ and $B$, call it $M$, is also given. Mark an arbitrary point $P$ on the plane. Using unmarked straight edge only, construct the line passing through $P$ and parallel to $AB$.
Mathematics news on Phys.org
Draw a random line through $M$, meeting $AP$ at $X$, and $BP$ at $Y$. Let $Z$ be the point of intersection of $BX$ and $AY$. I'll leave you to figure out why $PZ$ is parallel to $AB$.
Hint: What this does is to construct the line connecting $P$ to the harmonic conjugate of $M$ on the line $AB$ (which happens to be the point at infinity).
Opalg said:
https://www.physicsforums.com/attachments/412​
Thank You. I can conclude now using Ceva's theorem.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
