Constructing a balanced equation for KClO3+H2SO4
In summary, this question asks for a balanced equation for the reaction of KCl3 and H2SO4. Using oxidation numbers can be helpful, but there are many other ways to approach this problem.
chemdruid
Homework Statement :
This question is about the properties and reactions of the oxides of some elements in their +4 oxidation state. (a) Chlorine dioxide, Cl O2, is an important industrial chemical, used to bleach wood pulp for making paper, and to kill bacteria in water supplies. However, it is unstable and decomposes into its elements as follows. 2Cl O2(g) Cl 2(g) + 2O2(g)
Cl O2 can be made in the laboratory by reacting KCl O3 with concentrated H2SO4. Other products are K2SO4, KCl O4 and H2O. Construct a balanced equation for this reaction. You may find the use of oxidation numbers helpful.Cl O2 can be made in the laboratory by reacting KCl O3 with concentrated H2SO4. Other products are K2SO4, KCl O4 and H2O. Construct a balanced equation for this reaction. You may find the use of oxidation numbers helpful.
:[/B]
3KCl3+3H2SO4=3KHSO4+HClO4+2ClO2+H2O
But the question says K2SO4 and KClO4 are the other products.
Maybe i am getting the question wrong. Also how the oxidation number can be of help in this scenario?
Question lists both substances to be put on the LHS and substances to be put on the RHS, yet you used some other set of reagents for no apparent reason (I assume KCl3 is an obvious typo).
Have you tried to follow the question to the letter?
Oxidation numbers can help in balancing, I don't think they will be of other use here.
Likes chemdruid
Thanks Borek , the answer sheet says the balanced equation is:
3KClO3 + H2SO4 → K2SO4 + KClO4 + H2O + 2ClO2
Would appreciate a bit of explanation . thanks
Sorry, but I am no sure what you want explained. You are told what reacts with what and what the products are - simply plug these substances into the reaction equation and see if you are able to balance it. This is as trivial as a chemistry question can be.
Likes chemdruid
If you write the equation with unknown coefficients, aKCl+bH2SO4=cKHSO4+dHClO4+eClO2+fH2O, you can form a set of linear equations for the numbers a to f by requiring that there must be an equal number of similar atoms on the left and right side of the reaction equation. For instance, the balance equation for chlorine reads:
##a=d+e##, and the balance equation for oxygen is
##4b=4c+4d+2e+f##.
You will get five equations for six unknown numbers, so you have to decide to set one of the numbers to have a value of 1 to be able to solve the linear system.
Whipped this video up quickly. Does this help?
As you can tell by the answers, there are many approaches to this problem.
Likes chemdruid and Greg Bernhardt
Thank you .
Related to Constructing a balanced equation for KClO3+H2SO4
1. What is the balanced equation for the reaction between KClO3 and H2SO4?
The balanced equation for the reaction between KClO3 and H2SO4 is 2KClO3 + H2SO4 → K2SO4 + 2HClO3.
2. How do you balance the equation for KClO3 + H2SO4?
To balance the equation for KClO3 + H2SO4, you need to make sure that the number of atoms of each element is the same on both sides of the equation. This is achieved by adjusting the coefficients in front of each compound, while keeping in mind that you cannot change the subscripts.
3. What are the products of the reaction between KClO3 and H2SO4?
The products of the reaction between KClO3 and H2SO4 are K2SO4 and HClO3.
4. What is the molar ratio between KClO3 and H2SO4 in the balanced equation?
The molar ratio between KClO3 and H2SO4 in the balanced equation is 2:1. This means that for every 2 moles of KClO3, 1 mole of H2SO4 is needed to react completely.
5. How do you know if the equation for KClO3 + H2SO4 is balanced?
You can check if the equation for KClO3 + H2SO4 is balanced by counting the number of atoms of each element on both sides of the equation. If they are the same, the equation is balanced. You can also use the law of conservation of mass, which states that the total mass of the reactants must be equal to the total mass of the products.
  • Mechanical Engineering
10K
26K
