Constructing a Function F: Natural Restriction Homework
  • Thread starter benf.stokes
  • Tags
    Natural
In summary, the conversation discusses the construction of a function F(x) with a restricted domain of [0,plus infinity[ and a range in Rn, such that F(n) = x_n for all non-negative integers n, and that the limit as x approaches infinity of F(x) is equal to L if and only if the limit as n approaches infinity of x_n is also equal to L. An example function that satisfies these conditions is F(x) = sqrt(x)/(x^2+1).
benf.stokes
71
Let (xn) n ∈ N, be a succession. Construct a function F: [0,plus infinity[ to Rn (if possible
continuous) whose restriction to the naturals is (xn) n ∈ N, ie xn = F (n) for all n ∈ N, and such that ∃ limx → + ∞ F (x) = L if and only if ∃ Limn → + ∞ xn = L
What does restriction to the naturals mean? Does it mean that F(n) must be a natural? If so I can't find out what function has domain [0,plus infinity[ and produces naturals.
Thanks
What does restriction to the naturals mean? Does it mean that F(n) must a natural? If so I can't find out what function has domain [0,plus infinity[ and produces naturals.
Thanks
No, it is the domain, not the range, that is restricted. You are looking for a function, F(x), (where x can be any non-negative real number) such that for x= n, a non-negative integer, [itex]F(x)= F(n)= x_n[/itex].
For example, if [itex]x_n= 2/n[/itex], then you would take F(x)= 2/x.
Thanks for the reply. Would F(x) = sqrt(x)/(x^2+1) be an acceptable function then?
Looks to me like it will work. What is [itex]\lim_{x\to\infty}\sqrt{x}/(x^2+ 1)[/itex]?
What is [itex]\lim_{n\to\infty}\sqrt(n)/(n^2+ 1)[/itex]?
FAQ: Constructing a Function F: Natural Restriction Homework
What is a natural restriction in the context of constructing a function?
A natural restriction in constructing a function refers to the limitations or constraints that are inherent in a given situation. These restrictions can be physical, mathematical, or conceptual and must be considered when defining a function to accurately represent the situation.
How do you identify natural restrictions in a problem when constructing a function?
To identify natural restrictions, you must carefully analyze the given problem or situation. Look for any inherent limitations or constraints that may affect the function, such as physical barriers, mathematical constraints, or conceptual limitations. These restrictions may also be explicitly stated in the problem.
Can natural restrictions change the shape or behavior of a function?
Yes, natural restrictions can significantly impact the shape and behavior of a function. These restrictions can alter the domain and range of the function, limit the possible inputs or outputs, and affect the overall shape of the graph.
How can natural restrictions be addressed when constructing a function?
Natural restrictions can be addressed by carefully considering them when defining the function. This may involve adjusting the domain and range, including additional variables or constraints, or using appropriate mathematical operations to represent the limitations accurately.
What are some common examples of natural restrictions in real-world situations?
Some common examples of natural restrictions in real-world situations include physical boundaries such as walls or barriers, mathematical constraints such as negative numbers or division by zero, and conceptual limitations such as time or budget constraints. Other examples may include limitations on resources, technology, or human capabilities.
