Constructing a Line Segment Equal to a Circle's Circumference?
In summary, the conversation discusses the possibility of constructing a line segment with a length equal to the circumference of a circle using only a ruler and compass. The answer is "no" due to the transcendency of pi, which cannot be constructed with straightedge and compass. The concept of constructible lengths being included in certain Galois extensions of the rational numbers is also mentioned.
Trysse
53
Is there any way to construct a line segment, that has the lenght of the circumference of a circle using only a ruler and a compass?
My intuition says "no"
Or phrasing the question in another way: given two line segments, can I prove, that the longer line segment has the length of the circumference of a circle to which the shorter line segment is the radius/diameter?
Or In another way:, can I construct a circle, that has a circumference equal to a given line segment?
My intuition for "no" is based in the irrationality of Pi.
Mathematics news on Phys.org
Not the irrationality. Square root of two is irrational, but you can construct it. It is the diagonal of a square with unit length side.
Likes dextercioby, WWGD and FactChecker
"Squareing the circle" is known to be impossible with ruler and compass. I suspect this is the problem here, since having squared the circle (ie. constructed a line segment of length [itex]\sqrt{\pi}r[/itex] you can with ruler and compass construct a line segment of length [itex]\pi r^2[/itex], then from that and a line segment of length [itex]r[/itex] construct a segment of length [itex]\pi r[/itex], and finally double that to get a line segment of length [itex]2\pi r[/itex].
Likes Lnewqban
The answer is "no" due to the transcendency of ##\pi##. This means that ##\pi## cannot be written as
0=a_n\pi^n +a_{n-1}\pi^{n-1}+\ldots+a_2\pi^2+a_1\pi+a_0
with integers ##a_0,\ldots,a_n.##
The technical reason is: ##\pi## is not included in any Galois extension of the rational numbers.
Constructible lengths are included in certain Galois extensions of the rational numbers, namely those of degrees being a power of two, IIRC.
Likes dextercioby
Thanks, that was helpful.
Good point.
I knew that "squaring the circle" was impossible, but I did not make the connection.
fresh_42 said:
The answer is "no" due to the transcendency of π.
I knew the term transcendency but was unaware that this had a geometric consequence.
It's even stricter than this. Operations with a straightedge and compass can only introduce square roots, so a complex number number is constructible if and only if it is in a field extension of ##\mathbb{Q}## generated by iterated square roots. Not every extension of degree ##2^n## is a tower of quadratic extensions (and I also don't see why the extensions being Galois should be relevant).
IIRC was short for: "I am too lazy to look it up." van der Waerden had it around Galois-theory, so I took what was left in my memory. The statement itself wasn't false.
Likes SammyS
FAQ: Constructing a Line Segment Equal to a Circle's Circumference?
What is a line segment equal to a circle's circumference?
A line segment equal to a circle's circumference is a straight line that has the same length as the perimeter of the circle. The circumference of a circle can be calculated using the formula C = 2πr, where r is the radius of the circle.
How do you measure the circumference of a circle?
The circumference of a circle can be measured using a flexible measuring tape or a piece of string. Wrap the tape or string around the circle to find the total length, and then measure the length of the string or tape to determine the circumference.
What tools are needed to construct a line segment equal to a circle's circumference?
To construct a line segment equal to a circle's circumference, you typically need a compass, a straightedge (ruler without markings), and a pencil. These tools allow you to accurately draw the circle and the line segment.
Can you construct a line segment equal to a circle's circumference using only a compass and straightedge?
Yes, it is possible to construct a line segment equal to a circle's circumference using only a compass and straightedge. First, draw the circle and find its circumference using the radius. Then, you can use the compass to replicate that length in a straight line.
What is the significance of constructing a line segment equal to a circle's circumference in geometry?
This construction is significant in geometry as it demonstrates the relationship between linear and circular measurements. It helps in understanding concepts like pi (π) and the properties of circles, and it serves as a practical application of geometric principles in construction and design.
