I Constructing an Oriented Atlas for S1 (Self Study)
Amateur659
Hello,
I am trying to construct an oriented atlas for S1 by considering the 8 transitions from the basic coordinate projection atlas. However, it does not appear to be possible to modify this atlas without destroying existing progress.
Am I on the right track towards constructing the oriented atlas? Is there some other direction I should choose? Is there something obvious I am missing?
I've attached my work below.
Thank you for your time.
I think using Cartesian coordinates makes it unnecessarily complex. Instead use a one-coordinate system where the coordinate is angle from a given reference ray through the origin. Then your atlas needs only two charts. Make each one cover say 3/4 of the ring, and make the reference ray for the second one 180 degrees from the first reference ray. Then you have two overlapping part-rings covering the circle, each with a bicontinuous mapping to [0, 3 pi / 2], and quarter-circle overlaps at each end. You only have two overlap regions to look at, and in both the Jacobian is 1 x 1, ie a scalar.
Am I just obsessed if I always make my circle charts cover the full circle minus a point?
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
