Constructing Bondi Coordinates on General Spacetimes
In summary, Bondi coordinates can be defined on any spacetime and can locally describe any geometry. The construction for these coordinates involves choosing a null hypersurface with certain conditions on the null normals, and then defining two functions that are constant along the hypersurface generators. These functions become the angles in the coordinate system. The key condition for this construction is that the Jacobian of the coordinate transformation is not zero, ensuring that the coordinates form a chart. While there are rigorous proofs for the existence of other coordinate systems, such as Riemann normal coordinates and angular coordinates, the exact construction for Bondi coordinates on any spacetime is still unclear.
leo.
96
I'm trying to understand the BMS formalism in General Relativity and I'm in doubt with the so-called Bondi Coordinates.
In the paper Lectures on the Infrared Structure of Gravity and Gauge Theories Andrew Strominger points out in section 5.1 the following:
In the previous sections, flat Minkowski space in retarded coordinates near ##\mathscr{I}^+## was described by the metric $$ds^2=-du^2-2dudr+2r^2\gamma_{z\bar{z}}dzd\bar{z}. \tag{5.1.1}$$ We would now like to study gravitational theories in which the metric is asymptotic to, but not exactly equal to, the flat metric. We will work in Bondi coordinates ##(u,r,z,\bar{z})##, and we abbreviate ##\Theta^A = (z,\bar{z})##. In this gauge, the most general four-dimensional metric takes the form $$ds^2=-Udu^2-2e^{2\beta}dudr+g_{AB}\left(d\Theta^A + \frac{1}{2}U^A du\right)\left(d\Theta^B + \frac{1}{2}U^B du\right) \tag{5.1.2}$$
where $$\partial_r \det \left(\frac{g_{AB}}{r^2}\right)=0 \tag{5.1.3}$$
Equation (5.1.3) implies that ##r## is the luminosity distance.
So far we have not imposed any sort of assymptotic flatness condition. Any geometry can be described locally by the metric (5.1.2).
So he is saying that any metric tensor can be written like this, so in particular, coordinates like these can be defined on any spacetime.
So why is this true? Why can such coordinates be defined on any spacetime? What is the construction that gives rise to the coordinates ##(u,r,\Theta^A)## on any spacetime?
I've tried reading the original paper by Sachs from 1962 where he apparently introduces this, but I found quite confusing how this works out.
He picks any ##u \in C^\infty(M)## such that the level sets are null hypersurfaces with normals ##k_a = \nabla_a u##. Next, he imposes two conditions on such ##u##: first ##\rho = \frac{1}{2}\nabla_a k^a \neq 0## and second ##|\sigma|^2 = \frac{1}{2} \nabla_b k_a \nabla^b k^a -\rho^2 \neq \rho^2##.
Next he says we should pick any two functions ##\theta,\phi## with the property that they are constant along the generators of the hypersurface, namely ##k^a \nabla_a \theta = k^a \nabla_a \phi = 0##. He says that ##\rho\neq 0## implies that $$D = \nabla_a \phi \nabla^a \phi \nabla_b \theta \nabla^b \theta - (\nabla^a \phi \nabla_a \theta)^2 \neq 0.$$ Finally he claims such ##\theta,\phi## to be angles and defines ##r^4 = (D\sin^2\theta)^{-1}## and says ##r## is a luminosity distance.
This seems to be the construction Strominger has in mind. Still I can't understand the construction: (1) I don't get the two weird conditions imposed on ##u## in terms of ##\rho,|\sigma|^2##, (2) how could two arbitrary functions constant along the generators of the surace be angles? (3) What is the matter with that ##D## function (which is clearly a determinant?
Finally, I should say that nowhere in the construction the domain of validity of the chart on spacetime was pointed out, nor the ranges of the so-defined coordinates. Nor a proof that ##(u,r,\theta,\phi)## indeed provides a chart (a homeomorphism from spacetime to an open set of ##\mathbb{R}^4##).
So how to truly understand the construction of Bondi coordinates on a general spacetime? How to understand the intuition behind the steps, and how actually rigorously construct such coordinate system?
This is not something I am knowledgeable enough to give you an answer, so take it with the appropriate amount of salt. My impression is, and it may be far from true, that the work in the 60's, although mathematically rigorous, didn't not prove the existence of such space-times. Even the notion of asymptotically flat space-time wasn't fully understood. So you can take any of those papers as studying space-times with such properties, and you can take it for granted that they exists. I think, and again this may be completely wrong, that to see things done fully you need to look at the stability of Minkowski space-time work of Christodoulou and Klainerman. I believe that is where for the first time it was shown that such space-times exist and a fully rigorous construction of some of the notions was given, such as future null infinity, the optical function, the null foliation..
(1) These are the expansion and shear. The conditions simply exclude some unwanted cases, intuitively cylinder like and cone like cases. (2) I think the idea is that the intersections of ##u=const## and ##r=const## is a topological two-sphere, so a choice of coordinates can be called angles. (3) That is guaranteeing that they form a coordinate chart i.e. this is the condition that the Jacobian is not zero.
Likes Auto-Didact
@martinbn I thought the same when I've read section 2 of Sachs' paper the first time. But notice that Strominger points out that any geometry can be locally written in these coordinates with that metric tensor. I actually have the impression that it is true. My problem is that if any geometry admits such local description, then there must be a construction in an arbitrary geometry which yields these coordinates.
Take the Riemann normal coordinates for example. It is locally available on any geometry. And there is such a cosntruction: take one point ##z\in M##, build one orthonormal tetrad ##e_a## on the point. There is a neighborhood of the origin on which the exponential map is a diffeomorphism, let ##N## be the image, so that ##\exp_z^{-1}## is well defined on ##N##. Let ##q\in N## then ##\exp_z^{-1}(q)## can be expanded on ##e_a##. Define ##\exp_z^{-1}(q) = x^{a}(q)e_a##. The map ##x(q) = (x^a(q))## is a coordinate chart because ##\exp_z## is a diffeomorphism on the region of interest.
So you see: there is mathematical proof that we can construct the system, and the procedure which yields the coordinate functions.
Another example would be angular coordinates on a spherically symmetric spacetime like Schwarzschild spacetime. There is a derivation that shows how the existence of the angular coordinates follows from spherical symmetry.
I'm looking for what yields these Bondi coordinates on any spacetime. A construction which shows what is the domain of validity of the coordinates and the respective ranges. Unfortunately, up to this point I didn't find this.
You might be right that the coordinates exist locally.
Intuitively locally it should be possible. In Mikowski space-time the construction is clear. Any space-time is locally very close to Minkowski so it should be possible. Or you could do something similar to radar coordinates. Use light pulses to define your ##u## coordinate and the spheres, which in turn will define the angle coordinates and the areal radius.
Related to Constructing Bondi Coordinates on General Spacetimes
1. What are Bondi coordinates?
Bondi coordinates are a set of coordinates used in general relativity to describe spacetime. They were first introduced by Hermann Bondi in 1957 and are often used in the study of gravitational waves.
2. How are Bondi coordinates constructed?
Bondi coordinates are constructed by choosing a point in spacetime and defining a radial coordinate, a time coordinate, and two angular coordinates. These coordinates are then used to describe the geometry of the spacetime around that point.
3. What are the advantages of using Bondi coordinates?
Bondi coordinates have several advantages, including being well-suited for studying gravitational waves, allowing for a clear separation of the radial and angular components of spacetime, and being more convenient for calculations compared to other coordinate systems.
4. Are Bondi coordinates applicable to all types of spacetimes?
Bondi coordinates are most commonly used for describing asymptotically flat spacetimes, meaning those that become flat (or nearly flat) at spatial infinity. They can also be used for other types of spacetimes, but may require certain restrictions or modifications.
5. How have Bondi coordinates been used in scientific research?
Bondi coordinates have been used in various studies and calculations, particularly in the field of gravitational waves. They have also been used in the study of black holes, cosmology, and other areas of general relativity.
