Constructing Covering Spaces for Algebraic Topology Qualifier Exam Question
In summary, the question is about constructing a covering space ˜X for a given group representation X and a subgroup H. The group G of covering transformations and their actions on ˜X are also discussed for different cases of H.
yaa09d
This is a qualifier exam question in algebraic topology:
Let Z * Z_2 = <a, b | b^2> be represented by X = S^1 [tex]\vee[/tex] RP^2 , i.e. the wedge of S^1 (the unit circle)
and RP^2 (the real projective plane).
For the subgroup H below construct the covering space ˜X by sketching a good picture for ˜X and explaining how it covers X.
In each case, give a group presentation for the group G of covering transformations of the covering
p:˜X -----> X and describe (using your picture) the action of G on ˜X .
(a) H is the smallest normal subgroup containing b.
(b) H is the smallest normal subgroup containing a.
(c) H is the smallest normal subgroup containing a^2 and b.
(d) H is the trivial subgroup.
Attached is a pdf format of the question.
  • yy.pdf
For (a), H is the subgroup generated by b, and X has two components, the circle S^1 and the projective plane RP^2. The covering space ˜X is two copies of S^1 and one copy of RP^2. The group G of covering transformations is Z * Z_2 / <b>, which is Z_2. The action of G on ˜X is to swap the two copies of S^1.For (b), H is the subgroup generated by a, and X has two components, the circle S^1 and the projective plane RP^2. The covering space ˜X is two copies of S^1 and two copies of RP^2. The group G of covering transformations is Z * Z_2 / <a>, which is Z. The action of G on ˜X is to rotate the two copies of S^1 and swap the two copies of RP^2.For (c), H is the subgroup generated by a^2 and b, and X has two components, the circle S^1 and the projective plane RP^2. The covering space ˜X is two copies of S^1 and one copy of RP^2. The group G of covering transformations is Z * Z_2 / <a^2, b>, which is Z_2. The action of G on ˜X is to rotate the two copies of S^1 and swap the copy of RP^2.For (d), H is the trivial subgroup, and X has two components, the circle S^1 and the projective plane RP^2. The covering space ˜X is just X itself, so it is two copies of S^1 and one copy of RP^2. The group G of covering transformations is Z * Z_2, which is Z * Z_2. The action of G on ˜X is to rotate the two copies of S^1 and swap the copy of RP^2.
FAQ: Constructing Covering Spaces for Algebraic Topology Qualifier Exam Question
What is Algebraic Topology?
Algebraic Topology is a branch of mathematics that uses algebraic tools to study topological spaces. It focuses on the properties of spaces that are preserved under continuous deformations, such as stretching or bending, and uses algebraic structures to classify and compare different spaces.
How is Algebraic Topology used in real life?
Algebraic Topology has many practical applications, including in computer science, engineering, and physics. It can be used to model and analyze networks, such as transportation systems or computer networks, and to understand and design new materials with specific properties.
What are some key concepts in Algebraic Topology?
Some key concepts in Algebraic Topology include homotopy, which studies continuous deformations of spaces, homology and cohomology, which assign algebraic invariants to spaces, and fundamental groups, which describe the topological structure of spaces.
What kind of problems can Algebraic Topology solve?
Algebraic Topology can solve problems related to the classification and comparison of spaces, the detection of holes and higher-dimensional structures in spaces, and the study of symmetries and transformations of spaces. It can also be used to solve problems in other areas of mathematics, such as geometry and combinatorics.
How can I learn more about Algebraic Topology?
There are many resources available for learning Algebraic Topology, including textbooks, online courses, and video lectures. It is recommended to have a strong background in mathematics, particularly in abstract algebra and topology, before diving into Algebraic Topology. It is also helpful to work through practice problems and consult with experts in the field for a deeper understanding of the subject.
