Constructive Interference from Speakers on an x-axis
The maximum amplitude produced from the speakers is calculated to be 12.86 Pa. The user initially struggled with setting up the expression to find the distance to move one speaker, questioning whether to solve for phase difference. Clarification was requested from other forum members, emphasizing the need for an attempt to adhere to forum rules. After further work, the user successfully arrived at the correct answer, realizing the mistake was in converting degrees to radians for the phase calculation. This highlights the importance of careful unit conversion in wave interference problems.
ab200
Two speakers, A and B, are at the same point on an x-axis and each emits sound with a wavelength of 0.25 m. Speaker B's phase constant is 260 degrees larger than speaker A's phase constant and each produces an amplitude of 10 Pa.
What is the minimum distance you can move speaker A to achieve constructive interference along the x-axis? Give a positive answer regardless of direction, in m.
ΔΦ/2π = Δx/λ + ΔΦo/2π = m , m = 0,1,2,3...
The first part of this question asks for the maximum amplitude produced, which I found to be 12.86 Pa. I was able to set up the expression for the combined wave equations.
However, I am struggling to understand how to set up and solve an expression to find the distance I could move one of the speakers. I have wavelength, frequency, and amplitude, as well as difference in phase constant. Am I solving for phase difference?
It's not entirely clear what you mean by that. Please post an attempt based on that approach. An attempt is required by forum rules anyway, and it will clarify what you have in mind.
I apologize — after working on it again I arrived at the correct answer. I’m not entirely sure what I did the first time, but I suspect I didn’t convert degrees into radians when calculating difference in initial phase.
