jsed
- 12
I am trying to analyze the static stresses on a bronze bushing in a journal bearing if I was to use that journal bearing as a support for a cantilevered shaft. All the equations I have for contact stresses on the bushing suggest a uniformly distributed load across the entire bushing, which would be applicable if the shaft were supported by two bearings, but I am interested in what happens when the shaft is only supported on one end by one bearing.
Also, the manufacturer of the bushing states that the bushing can withstand 8000 psi of static load, which represents the load on the projected bearing area (ID x Length). Based on this criteria, I am not sure if contact stresses are what I need to be looking at. I also know the compressive yield strength of the bushing material, so I could just use that to analyze the static failure of the material.
Thank you for your input.
