HTML/CSS Container shrinks at certain screen widths (CSS)
  • Thread starter Thread starter Darkmisc
    Bootstrap Css
The discussion centers on a user trying to add a banner above a Bootstrap navbar that fills 100% of the screen width. The user encounters issues where the banner and parent div shrink at specific screen widths (887px and 464px), despite using media queries to maintain a 100% width. They attempted to fix the issue by adjusting the CSS but did not achieve the desired results. The user tested various configurations, including setting widths to 150% to see if media queries were functioning, which led to the banner appearing but not as intended. They also explored using fixed positioning for the parent and banner elements but faced visibility issues. A suggestion was made to isolate the banner in a separate div to apply CSS more effectively. Ultimately, it was discovered that an image in the footer was causing overflow issues, which contributed to the navbar's perceived shrinking at certain widths. The user concluded that the navbar was not shrinking; rather, the footer image was exceeding the container's width.
Darkmisc
TL;DR Summary
I want to make a sticky navbar with a banner above it. The sticky navbar spans 100% of the screen for all screen widths, but the banner will shrink at seemingly random points so that it doesn't always fill 100% of the width.
Hi everyone
I have a Bootstrap navbar and I'd like to add a banner above it. The Bootstrap navbar fills 100% of the screen width for all screen widths.
I've added a styled component to make a Parent div and a Banner div. These occupy 100% of the screen width most of the time, but at 887px and 464px they shrink (see below).
I've had a similar issue before with a container and was able to fix it by using media queries to set the width back to 100%. I tried this again, but it didn't work.
Lines 12-43 are the only lines that I've added to the Bootstrap code. I also tried using Bootstrap to make the Parent and Banner, but got the same result.
Here is the code for the page.
[CODE lang="css" title="StickNavbar.js" highlight="12-43"]import React, { useEffect } from 'react';
import { Link } from 'react-router-dom';
import Example from './Modal';
import { FontAwesomeIcon } from '@fortawesome/react-fontawesome';
import { faPhone } from '@fortawesome/free-solid-svg-icons';
import { useGlobals } from '../../Globals';
import "./BNavbar.css";
import logo from "../../images/MJNNavbarlogo.png";
import styled from 'styled-components';
const Parent = styled.div`
display:grid;
background:blue;
width:100vw;
@media screen and (max-width: 887px) {
display: grid;
width:100%;}
@media screen and (max-width: 464px) {
display: grid;
width:100%;}
const Banner = styled.div`
display:grid;
height: 80px;
width: 100%;
width:100vw;
background: rgba(255, 0, 0, 0.5); /* Red with 50% opacity */
display: grid;
width:100%;}
display: grid;
width:100%;}
const StickyNavbar = () => {
const { PrimaryColour, GlobalFont } = useGlobals();
useEffect(() => {
// Set the CSS variable for primary color
document.documentElement.style.setProperty('--primary-color', PrimaryColour);
// Set the CSS variable for global font
document.documentElement.style.setProperty('--global-font', GlobalFont);
}, [PrimaryColour, GlobalFont]);
const navbarStyle = {
backgroundColor: PrimaryColour,
height: "80px",
boxShadow: '0 4px 8px rgba(0, 0, 0, 0.3)',
position: 'fixed',
top: "80px",
left: 0,
width: '100%',
zIndex: 1000,
alignItems: "center",
return (
<Parent>
<Banner/>
<nav className="navbar navbar-expand-lg" style={navbarStyle}>
<Link className="navbar-brand" to="/">
<img src={logo} alt="Logo" />
</Link>
<button className="navbar-toggler" type="button" data-bs-toggle="collapse" data-bs-target="#navbarNav" aria-controls="navbarNav" aria-expanded="false" aria-label="Toggle navigation">
<span className="navbar-toggler-icon"></span>
</button>
<div className="collapse navbar-collapse custom-navbar-collapse" id="navbarNav">
<ul className="navbar-nav ml-auto">
<li className="nav-item active">
<Link className="nav-link" to="/">Home</Link>
</li>
<li className="nav-item dropdown">
<a className="nav-link dropdown-toggle" href="#" id="navbarDropdown" role="button" data-bs-toggle="dropdown" aria-expanded="false">
Services
</a>
<ul className="dropdown-menu" aria-labelledby="navbarDropdown">
<li><Link className="dropdown-item" to="/services"
style={{ fontFamily: 'Roboto, sans-serif' }}
>Services</Link></li>
<li><Link className="dropdown-item" to="/services/development"
style={{ fontFamily: 'Roboto, sans-serif' }}>Development</Link></li>
<li><hr className="dropdown-divider" /></li>
<li><Link className="dropdown-item" to="/services/support"
>Support</Link></li>
</ul>
</li>
<li className="nav-item d-flex align-items-center custom-phone-number" style={{ marginLeft: "25px" }}>
<FontAwesomeIcon icon={faPhone} className="me-2" />
<a href="tel:0412123456" className="nav-link phone-number">
0412 123 456
</a>
</li>
<li className="nav-item active" style={{ marginLeft: "25px" }}>
<Example buttonText="Contact Us" />
</li>
</ul>
</div>
</nav>
</Parent>
export default StickyNavbar;
[/CODE]
I think the media queries work (just not in the way that I'd like). I tested to see what would happen if I used the media query to set the width to 150%. This makes the pink part appear, which didn't happen before.
Does anyone know what's happening? I don't understand why I'm getting issues at (seemingly) random widths. Using media queries fixed a similar problem, and I don't understand why it's not working here also.
Thanks
Technology news on Phys.org
Is this what you are trying to achieve:
HTML:
<style>
#parent{
    background: blue;
    width: 100vw;
    position: fixed;
    top: 0;
    height: 160px;
#banner{
    background: red;
    height: 80px;
    position: fixed;
    width: calc(155vw - 487px);
    max-width: 100vw;
    min-width: 50vw;
#menu{
    background: green;
    height: 80px;
    position: relative;
    top: 80px;
    left: 0;
    width: 100vw;
</style>
<div id=parent>
    <div id=banner>BANNER</div>
    <div id=menu>MENU</div>
</div>
Where the width of the banner calc(Avw - Bpx) is found by solving these two equations:
$$\frac{A}{100} W_{max} - B = W_{max}$$
$$\frac{A}{100} W_{min} - B = 0.5W_{min}$$
Where:
$$A = 100 \times \frac{W_{max} -0.5 W_{min}}{W_{max} - W_{min}}$$
$$B = \left( \frac{A}{100} - 1 \right) W_{max}$$
In your case for ##W_{max} = 887\ px## and ##W_{min} = 464\ px##, you get:
##A = 155##
##B = 487##
This will give you a full screen width at 887 px or more and a 50% screen width at 464 px or less and, of course, the banner width will be somewhere between 50% and 100% of the screen width anywhere else.
Using position:fixed in parent made the navbar and banner disappear, so I left the position as relative.
Using position:fixed in Banner made the banner disapppear (navbar was still there), so I had to use relative for that too.
Here's the code I ended up trying.
CSS:
    width: 100vw;
    background:blue;
    height:160px;
    position: relative;  // bars won't show with asbolute or fixed.
    top: 0;
    height: 80px;
    width:100%;
    position: relative;
    max-width: 100vw;
    min-width: 50vw;
const Menu = styled.div`
    background: green;
    height: 80px;
    position: relative;
    // top: 80px;
    left: 0;
    width: 100vw;
There was no particular significance to the 150% in my original code. I just wanted to test if the media query worked. I'm a bit puzzled why the media query works to make the navbar wider than 100%, but seems to do nothing to keep the width at 100% (which is what I'm aiming for).
I thought I'd try a workaround where the banner appears in another file and I just push the navbar down to leave a blank space. I messed it up (banner now appears under the navbar).
Anyhow, when the navbar appears on top, it becomes the thing to shrink, with the banner always being 100% screen width.
Does this provide any clues as to what's going on?
You will have to find out why this happens because position: fixed is the only way to make a "sticky" element on your screen.
I don't understand why your navbar and parent are sharing the width of the banner. I'm not an expert with React, so I'm not sure how <Banner/> translates into HTML. Maybe you need to put this banner into a div to isolate it and apply the CSS to this div instead of the banner?
I think I found the problem. I had an image in the footer that wasn't shrinking with its container. That image was 464px at its smallest.
I don't know why it also created a problem at 887px, but it seems to be gone now.
So my navbar wasn't actually shrinking. It was that the image in the footer was overflowing beyond 100%.
Likes jack action
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
