Continous signals as sums of weighted delta functions
In summary: No, the idea behind convolution is that by combining two random functions, you can create a new, more complex, function.
LLT71
73
so, continuous signals as sums of weighted delta functions can be represented like this:
if you switch order of some variables you get ∫x(τ)δ(-τ+t)dτ, and since,I presume, Dirac delta "function" is even I can write it like this ∫x(τ)δ(-(-τ+t))dτ=∫x(τ)δ(τ-t)dτ=x(t) and we got ourselves a "sifting property". can we visualize it like this:
x(τ) is function in "τ domain". for every τ there is x(τ) such that every x(τ) value represents some function x(t) which can be "extracted" using δ(τ-t) or, generally speaking, function x(τ) in τ domain represents some "family of functions" x(t) and by using sifting property, described earlier, we can sift one particular function x(t) from that family?
if this is right, can described sifting property be some kind of "transformation" like Laplace one (you go from one to domain to another, do some things, and go back to original domain)?
thanks!
Your variable manipulations make no difference to the meaning or interpretation of your expression. With your notation
$$ x(t) = \int_{-\infty}^\infty x(\tau) \delta(t-\tau)\, d\tau \, = \, \int_{-\infty}^\infty x(\tau) \delta(\tau-t)\, d\tau$$
is the definition of the delta function. It says that convolving a function ##x## with the delta function gives you the same function ##x##.
LLT71 said:
... generally speaking, function x(τ) in τ domain represents some "family of functions" x(t) and by using sifting property, described earlier, we can sift one particular function x(t) from that family?
Nope. There is no difference between ##x(\tau)## and ##x(t)##; they are both the same function. The argument is a dummy variable.
Jason
Likes LLT71
Jason
so, basically sifting property $$ \, \int_{-\infty}^\infty x(\tau) \delta(\tau-a)\, d\tau = x(a) $$ would give us one particular value of function $$ x(a) $$ since a=const., but
$$ \, \int_{-\infty}^\infty x(\tau) \delta(\tau-t)\, d\tau = x(t) $$ is like picking every value of function (for every t, since t isn't constant [t=time]) using Dirac impulse ("walking Dirac impulse underneath the function" from -inf to +inf) and at the same time summing all of infinitely narrow weighted Dirac impulses (integration) gives you function x(t)? so, that's the idea behind convolution? and dummy variable gives you freedom to escape for a moment variable t and gives you opportunity to manipulate (slide) functions at will? okay, I think I understand at some point significance and meaning of recreating function using Dirac delta impulses but what is the significance behind convolution of any two randomly choosen signals (functions)? I don't understand what convolution, even as plain English word, really means, so maybe it would be helpful if someone give me a proper non-mathemathical definition (and include some analogies) of convolution for a moment. thanks!
This just uses the delta function to pick out the single value of the function x at a while ignoring all other values of x. Your rewritten version is such a degenerate example of convolution that I am not sure it illustrates anything significant about convolution in general. (Maybe I just don't have enough imagination to see more significance.)
I wouldn't over-think it if I were you.
I'm sorry I used the concept of convolution to answer your question; it was not the best way to explain what you are trying to learn and it is causing more confusion than help.
In all of the equations above, just think of ##x(t)## as the value of the function ##x## at a particular ##t##. Indeed, that is how a mathematician would typically interpret the notation. So all of the integrals above simply are examples of the sifting property of the delta function.
Jason
Likes LLT71
well, for me it illustrates an understanding how it works. instead of Dirac function write any function and make it generalised and you get convolution integral, so instead of $$ \, \int_{-\infty}^\infty x(\tau) \delta(\tau-t)\, d\g = x(t) $$, write $$ \, \int_{-\infty}^\infty x(\tau) g(\tau-t)d\g = (x*g)(t) $$ where ##g(τ-t)## can be any function (including Dirac delta "function"). based on Wikipedia illustration on convolution I think my version have at least some sense. you choose one function to be "fixed" ##x(t)## and you choose another one to "walk" from -inf to +inf ##g(τ-t)##.
Yes, that a correct understanding of convolution (although saying that one function is "fixed" may be misleading). And the delta function is the identity function for convolution. f*δ = δ*f = f.
Likes LLT71
FactChecker said:
Yes, that a correct understanding of convolution. And the delta function is the identity function for convolution. f*δ = δ*f = f.
nice! what is an idea of taking convolution of two functions? what is convolution, generally speaking (plain English)? thanks!
An application of convolutions that I like to think of is when you have a sequence of two operations, f and g, done in series. The operations f and g have different responses (delays, gains, etc.), to an input at delayed times τ.
Here is a rough, informal description of what I mean. Suppose an input signal I(t) is sent into operations f and then to g to get the output signal O(t): I => f => g => O
Then the output at time t is the integral of all effects of f and g where the total time through is t. So at any time, t, you want the cumulative response of f and g where the delays add up to t: t = τ + (t-τ). That is, you want to determine the combined effects of f and g: C(t) =[∫f(τ)Ig(t-τ)dτ]. Then O = C * I.
PS. This could have been a simpler example:
Consider I => f => O. The output O(tO) at time tO is the cumulative response of f to the input I over all combinations of input time tI and delay time tf that combine to tO. That is all τf where tO = tI + τf. The cumulative response is O(tO) = [∫f(τf)I(tOf)dτf]
Likes LLT71
Related to Continous signals as sums of weighted delta functions
1. What are continuous signals?
Continuous signals are defined as signals that can take on any value over a continuous range of time or space. They are represented by a continuous function, where the output can vary infinitely between any two points.
2. What are weighted delta functions?
Weighted delta functions are mathematical functions used to represent a discrete spike or impulse in a continuous signal. They are defined as a combination of a Dirac delta function and a weight, which determines the amplitude of the spike at a specific point in the signal.
3. How are continuous signals represented as sums of weighted delta functions?
Continuous signals can be represented as a sum of weighted delta functions through the process of sampling and reconstruction. Sampling involves taking discrete samples of a continuous signal at regular intervals, and reconstruction uses these samples to reconstruct the original continuous signal by weighting and summing the delta functions at each sample point.
4. What is the significance of using weighted delta functions in signal processing?
Weighted delta functions are used in signal processing to represent sharp changes or impulses in a continuous signal, which can be useful in analyzing and processing signals. They are also used in signal reconstruction to accurately reconstruct the original signal from discrete samples.
5. Can continuous signals be perfectly represented as sums of weighted delta functions?
No, continuous signals can only be approximated by sums of weighted delta functions. This is because delta functions are infinitely narrow and cannot perfectly represent the continuous nature of a signal. However, as the number of weighted delta functions used increases, the approximation becomes more accurate.
  • Calculus
