Continuity across boundaries in Electromag
  • Thread starter fantispug
  • Tags
    Continuity
Your Name]In summary, the conversation discusses the continuity of the electric field and conductivity across the boundary between two regions in a medium with no net charge, where Ohm's law holds. The question asks to prove that the product of the electric field and the permittivity is continuous across the boundary. By using the continuity equation for current and the product rule for the divergence, it is shown that the electric field is always perpendicular to the gradient of the conductivity, leading to the conclusion that the conductivity and permittivity must be continuous across the boundary.
fantispug
105
This question is adapted from an implicit assumption in Ashcroft and Mermin question 1.5.
Consider a medium with no net charge (but possibly a net current) in which Ohm's law holds. Let an electromagnetic wave travel through the medium with angular frequency [tex]\omega[/tex]. Then, by Maxwell's equations, the electric field satisfies
[tex]-\nabla^2 \mathbf{E} = \frac{\omega^2}{c^2} \epsilon(\omega) \mathbf{E} [/tex] for some appropriate function [tex] \epsilon(\omega)[/tex], where c is the speed of light.
Consider the boundary between two such regions (which may contain surface charge). Prove that [tex] \epsilon \mathbf{E}^{\bot}[/tex] is continuous across the boundary.
The surface charge between two regions is given by the discontinuity of the perpendicular component of the electric field.
[tex] E^{\bot}_{\text{above}} - E^{\bot}_{\text{below}} = \frac{\sigma}{\epsilon_0} [/tex]
I don't think it's true. Given the perpendicular component of [tex]\epsilon \mathbf{E}[/tex] is continuous across the boundary, using the definition of [tex]\epsilon[/tex] we see
[tex] -\nabla^2 (E^{\bot}_{\text{above}} - E^{\bot}_{\text{below}}) = 0 [/tex]
that is
[tex] \nabla^2 \sigma = 0 [/tex].
I don't see any a priori reason this should be true (given this I could run the argument backwards to prove the assertion). I think this would be the crux of the argument; and indeed I can not see another way to approach the problem.
Any help on what I'm missing?
Cheers.
Thank you for bringing up this interesting question. I believe the issue here is that you are assuming that the surface charge is constant across the boundary, which is not necessarily true. The surface charge on each side of the boundary may be different, but the electric field should still be continuous across the boundary. This is because the electric field is determined by the distribution of charges, not just the surface charge.
To prove this, we can use the continuity equation for current, which states that the divergence of current density is equal to the rate of change of charge density. In this case, since there is no net charge in the medium, the rate of change of charge density is zero and the continuity equation reduces to:
\nabla \cdot \mathbf{J} = 0
Using Ohm's law, we can express the current density as:
\mathbf{J} = \sigma \mathbf{E}
where \sigma is the conductivity of the medium. Substituting this into the continuity equation, we get:
\nabla \cdot (\sigma \mathbf{E}) = 0
Using the product rule for the divergence, this becomes:
\sigma (\nabla \cdot \mathbf{E}) + \mathbf{E} \cdot (\nabla \sigma) = 0
Since \nabla \cdot \mathbf{E} = 0 (by Gauss's law), we can rearrange this equation to get:
This implies that the electric field is always perpendicular to the gradient of the conductivity. Now, going back to the original problem, we can see that since the electric field is continuous across the boundary, the gradient of the conductivity must also be continuous. This means that the conductivity itself is continuous, since the gradient of a function is continuous if the function is continuous. And since the conductivity is related to \epsilon by \sigma = \epsilon \omega, we can conclude that \epsilon is also continuous across the boundary.
I hope this helps to clarify the issue. Let me know if you have any further questions.
FAQ: Continuity across boundaries in Electromag
What is meant by "continuity across boundaries" in electromagnetism?
Continuity across boundaries in electromagnetism refers to the principle that the electric and magnetic fields must remain continuous and consistent at the interface between two different materials or regions. This means that the electric and magnetic fields must have the same magnitude and direction on both sides of the boundary.
Why is continuity across boundaries important in electromagnetism?
Continuity across boundaries is important because it ensures that the laws of electromagnetism, such as Gauss's Law and Faraday's Law, hold true at the interface between different materials. This allows for a smooth transition of electromagnetic fields and helps to accurately predict and understand the behavior of electromagnetic waves.
How does continuity across boundaries affect the behavior of electromagnetic waves?
The principle of continuity across boundaries helps to determine how electromagnetic waves will behave at the interface between different materials. For example, if there is a sudden change in the dielectric constant or magnetic permeability at a boundary, the electromagnetic wave may be reflected, transmitted, or refracted depending on the angle of incidence and the properties of the materials.
Does continuity across boundaries only apply to interfaces between different materials?
No, continuity across boundaries applies to any interface or boundary where there is a change in the properties of the medium through which an electromagnetic wave is traveling. This could include interfaces between different materials, as well as interfaces between different regions of the same material with varying properties.
Are there any exceptions to the principle of continuity across boundaries in electromagnetism?
In most cases, continuity across boundaries holds true in electromagnetism. However, there are some exceptions, such as at the interface between two different metals, where there can be a discontinuity in the electric and magnetic fields due to the presence of surface charges and currents. These exceptions are typically accounted for and explained by the laws of electrostatics and magnetostatics.
