Continuity And Differentiability
In summary, the homework statement is trying to prove that cosine is continuous on R and differentiable on R. They are stumped on how to do this and are looking for help. They found that cosine is continuous and differentiable using the identity cos(x+-y)=cos(x)cos(y)-+sin(x)(sin(y)), but they are not allowed to do so. The continuity part is correct. For the derivative, they are trying to use something similar to the chain rule to derive sin(\pi/2 -x) which is differentiable to -1. Sin(x) is differentiable with sin(x)'=cos(x) so [sin(\pi/2 - x)]
wany
72
So I am to prove that cosine is continuous on R and differentiable on R. I already proved it for sine which was simple by using the identity of sin(x +- y)=sin(x)cos(y)+-cos(x)sin(y)
Now I need to prove it for cosine and also we cannot use the identity of cos(x+-y)=cos(x)cos(y)-+sin(x)(sin(y)
We do know that [itex]sin^2(x)+cos^2(x)=1[/itex] and [itex]cos(x)=1-2sin^2(x/2)[/itex]
[itex]cos(x)=sin(\pi/2 - x)[/itex], [itex]sin(x)=cos(\pi/2 - x)[/itex], [itex]cos(-x)=cos(x)[/itex], [itex]sin(-x)=-sin(x)[/itex]
sin(0)=0, cos(0)=1, [itex]|sin(x)| \le 1, |cos(x)| \le 1[/itex]
and [itex]0 < xcos(x) < sin(x) < x, 0 < x \le \pi/2[/itex]
So to prove that it is continuous I was thinking using [itex]cos(x)=sin(\pi/2 - x)[/itex]
so we can say that [itex]{\lim }\limits_{x \to a} cos(x)=\limits_{x \to a} sin(\pi/2 -x)=sin(\pi/2 -a)=cos(a)[/itex]
Would this be correct?
Now to prove that cos(x) is differentiable I am stumped. We do know that sin(x) is differentiable and also that [itex]{\lim }\limits_{x \to 0} sin(x)/x=1[/itex] and [itex]{\lim }\limits_{x \to 0} (1-cos(x))/x=0[/itex]
I know how to prove both using the identity cos(x+-y)=cos(x)cos(y)-+sin(x)(sin(y), but we are not allowed to do so.
For the derivative, try something similar. Try deriving [tex]\sin(\pi/2 -x)[/tex] with the chain rule.
Ok, so using the chain rule we know that [itex]\pi/2 -x[/itex] is differentiable to -1.
So by the chain rule [itex][cos(x)]'=[sin(\pi/2 - x)]'=[sin(\pi/2 - x)]'*(\pi/2 - x)'=[sin(\pi/2 - x)]'*(-1)[/itex]
Since sine is differentiable with sin(x)'=cos(x) then [itex][sin(\pi/2 - x)]'=cos(\pi/2 - x)=sin(x)[/itex]
So therefore [itex][sin(\pi/2 - x)]'*(-1)=sin(x)*(-1)=-sin(x)[/itex]
Is this the correct way?
And thank you so far for your help.
That seems to be correct!
Cool. Thank you very much.
Related to Continuity And Differentiability
1. What is the definition of continuity?
The definition of continuity is the property of a function where the output changes smoothly as the input changes, without any abrupt jumps or breaks. In other words, a function is continuous if there are no gaps or holes in its graph.
2. How do you determine if a function is continuous at a specific point?
A function is continuous at a specific point if the limit of the function at that point exists and is equal to the value of the function at that point. In other words, the left-hand limit, right-hand limit, and the value of the function at the point must all be equal.
3. What is the difference between continuity and differentiability?
Continuity refers to the smoothness of a function, while differentiability refers to the existence of the derivative of a function. A function can be continuous but not differentiable at a specific point, meaning there is a smooth change in the output but the derivative does not exist at that point.
4. How can you determine if a function is differentiable?
A function is differentiable if the derivative of the function exists at every point in its domain. This means that the function must be continuous and have a well-defined tangent line at every point on its graph.
5. What is the relationship between continuity and differentiability?
The relationship between continuity and differentiability is that a function must be continuous in order to be differentiable. However, a function can be continuous without being differentiable at certain points. In other words, continuity is a necessary but not sufficient condition for differentiability.
