Continuity in terms of closed sets
In summary: Since $f(p) \notin C$, it follows that $p \notin f^{-1}(C)$, as desired. In summary, A function $f: X \to Y$ is continuous if and only if the inverse image of any closed set is closed. For the first implication, if $V \subset Y$ is a closed set, then $f^{-1}(V)$ is also closed. For the second implication, if $p \in X$ and $C$ is a closed set in $Y$ such that $f(p) \notin C$, then $p \notin f^{-1}(C)$ as well. Therefore, proving that $f(p) \in Y - C$ and $f
Fantini
MHB
268
Hello. I wish to prove this:
$$\text{A function } f: X \to Y \text{ is continuous if and only if the inverse image of any closed set is closed.}$$
Proof: $(\implies)$ Let $V \subset Y$ be a closed se. By definition, $Y-V$ is an open set, and by the continuity of $f$ it follows that $f^{-1}(Y-V)$ is open in $X$. Thus, $f^{-1}(Y-V) = f^{-1}(Y) - f^{-1}(V) = X - f^{-1}(V)$ is open, and therefore $f^{-1}(V)$ is closed.
For the second implication, let $p \in X$ and $C$ a closed set in $Y$ such that $f(p) \notin C$. Thus $f(p) \in Y - C = V$, and by hypothesis $f^{-1}(C)$ is closed in $X$, with $p \notin f^{-1}(C)$. Hence $p \in X - f^{-1}(C) = U$, which is an open set. Therefore, we have an open set $U$ in $X$, with $p \in U$ and $f(p) \in V$ open in $Y$, such that $f(U) \subset V$. $\blacksquare$
My restlessness lies in the second implication. Is it right to assume that if $f(p) \notin C$ then $p \notin f^{-1}(C)$? Thanks. (Yes)
Fantini
Fantini said:
Hello. I wish to prove this:Is it right to assume that if $f(p) \notin C$ then $p \notin f^{-1}(C)$?
Yes, it is right. By definition $p\in f^{-1}(C)\Leftrightarrow f(p)\in C.$
FAQ: Continuity in terms of closed sets
What is continuity in terms of closed sets?
Continuity in terms of closed sets is a mathematical concept that describes the relationship between a function and its domain and range. It means that for a function to be continuous, the pre-image of any closed set in the range must be a closed set in the domain.
How is continuity defined in terms of closed sets?
Continuity in terms of closed sets is defined as follows: A function f is continuous if for any closed set C in the range of f, the pre-image of C under f, denoted by f-1(C), is a closed set in the domain of f.
What is the importance of continuity in terms of closed sets?
Continuity in terms of closed sets is important because it allows us to determine if a function is continuous without having to look at the function itself. It also helps in proving the continuity of a function in more complex situations.
Are all continuous functions also continuous in terms of closed sets?
Yes, all continuous functions are also continuous in terms of closed sets. This is because the definition of continuity requires the pre-image of every open set to be open, and since closed sets are the complements of open sets, the pre-image of a closed set must also be closed for the function to be continuous.
Can a function be continuous in terms of closed sets but not continuous?
No, a function cannot be continuous in terms of closed sets but not continuous. This is because the definition of continuity in terms of closed sets is a stronger condition than regular continuity, and a function that satisfies the former must also satisfy the latter.
