MHB Continuity of a Function .... Conway, Definition 1.7.1 .... ....
Math Amateur
MHB
I am reading John B. Conway's book: A First Course in Analysis and am focused on Chapter 1: The Real Numbers ... and in particular I am focused on Section 1.7: Continuous Functions ...
I need help with clarifying Definition 1.7.1 ...Definition 1.7.1 reads as follows:
View attachment 9497My question is as follows:
Is the above definition clear and correct? Is it usual?It seems to me Conway has defined continuity at any point $$x \in X$$ ... so why bother mentioning $$a$$ ... ?Can someone please clarify Conway's approach to continuity ...
Peter
Peter
And HOW did he define "at any point [math]x\in X[/math]? As being continuous at every a\in X. That wouldn't make sense unless he had defined "continuous at a" first!
Hi HallsofIvy ...
This is Conway's first and only definition of continuity for a real valued function of a real variable ...
I feel that there is a typo in it since as it stands it doesn't seem to make sense ...
Peter
Peter
You are quite correct, and once again you have found a typo in a respected textbook. Here, Conway claims to be defining continuity at $a$, but he actually defines continuity at $x$. In other words, he changes notation halfway through the definition.
There are two ways of defining continuity. One is the $\varepsilon$-$ \delta$ definition, the other (used here by Conway) is to use sequences. Both definitions are "usual", and they are equivalent to each other. Each of them is useful in different contexts. Whichever of them is taken as the initial definition, most authors find it helpful to introduce the other one later, and to prove their equivalence.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
