Continuity of IVP: Show $\lim_{y_0\to x_0}u(t,y_0)=u(t,x_0)$
In summary, the given conversation discusses the solution for the initial value problem of a matrix with real and distinct eigenvalues. It is shown that for each fixed time, the limit of the solution as the initial value approaches the given value is equal to the solution at that initial value. The general solution for the IVP is also mentioned to be linear and continuous.
Krizalid1
109
Let $A_{n\times n}$ be a matrix with real and distincts eigenvalues. Let $u(t,x_0)$ be a solution for the initial value problem $\overset{\cdot }{\mathop{x}}\,=Ax$ with $x(0)=x_0,$ then show that for each fixed $t\in\mathbb R,$ we have $$\lim_{y_0\to x_0}u(t,y_0)=u(t,x_0).$$
Mathematics news on Phys.org
[sp]The general solution of the IVP is $\displaystyle u(t,x_{0}) = c_{0}\ A\ e^{\lambda\ t}$, where $\displaystyle c_{0}= x_{0}\ A^{-1}$, so that $u(t,x_{0})$ is linear in $x_{0}$ and therefore continous...[/sp]Kind regards $\chi$ $\sigma$
FAQ: Continuity of IVP: Show $\lim_{y_0\to x_0}u(t,y_0)=u(t,x_0)$
What is the meaning of "continuity of IVP"?
Continuity of IVP refers to the property of a function in which a small change in the initial value results in a small change in the solution. In other words, if the initial value of a function is changed by a small amount, the resulting solution should also change by a small amount.
What is the importance of continuity of IVP?
Continuity of IVP is important because it ensures that the solution to a differential equation is stable and reliable. It also allows us to use numerical methods to approximate the solution, as small changes in the initial value will not significantly affect the accuracy of the solution.
How is continuity of IVP related to the existence and uniqueness theorem for differential equations?
The existence and uniqueness theorem states that a differential equation has a unique solution if the initial value is specified. Continuity of IVP is a necessary condition for this theorem to hold. If a function is not continuous at the initial value, there may be multiple solutions to the differential equation.
Can continuity of IVP be violated?
Yes, it is possible for continuity of IVP to be violated. This can happen if the function is not continuous at the initial value, or if the function is not differentiable at the initial value. In these cases, the solution to the differential equation may not be unique and may not exhibit the expected behavior.
How is continuity of IVP verified?
Continuity of IVP can be verified by checking if the function is continuous and differentiable at the initial value. This can be done analytically or numerically by using numerical methods to approximate the solution and checking for small changes in the initial value.
