I Continuity of Quotient of Complex Values
The discussion centers on the continuity of the function f(a) = √((a - 1i)/(a + 1i)) as a approaches zero. It highlights that the discontinuity arises from the square root function's branch cut, which causes a sign flip in the imaginary part when a small value is introduced. The principal branch of the square root function is conventionally defined, leading to discontinuities at the negative real axis. The behavior of f(a) differs for values approaching zero from the left and right, revealing that the function is not continuous at that point. Adjusting the branch of the square root can resolve the discontinuity, ensuring continuity in the function's behavior.
thatboi
Hey all,
I have a very simple question regarding the quotient of complex values. Consider the function:
$$f(a) = \sqrt{\frac{a-1i}{a+1i}}$$
where ##i## is the imaginary unit. When I evaluate f(0) in Mathematica, I get ##f(0) = 1i##, as expected. But if I evaluate at a very small value of ##a## such as ##a = 10^{-20}##, I get ##f(10^{-20}) = 10^{-20} - 1i##. I naively thought that ##f## would be continuous in ##a## but it is clear that somehow the imaginary part of ##f## flips sign the moment I introduce some small value for ##a##. How do I explain this behavior? I feel like there is something obvious here I am missing.
Thanks!
Mathematics news on Phys.org
The problem is not in the quotient, it is in the square root function. The square root of any real number, ##r \in \mathbb{R}, r \gt 0## can be positive or negative. It is a matter of convention that the positive number is considered the "principle branch" and is the answer given. That means that the "principle branch" excludes the negative answers, which are in another (non-principle) branch. The negative real axis in the z domain is called a "branch cut". When your input crosses the branch cut there will be a discontinuity because the continuous answer would cross into a different branch answer. That is what happened in your example. (see this )
Likes PeroK, thatboi and andrewkirk
The problem arises from the use of the square root sign as if it denoted a function - ie a map that can only give one value per input. Recall that every complex number has square roots, Each is -1 times the other. So to make the square root sign able to work as a function we need to adopt a convention as to which of the two roots we select, For square roots of positive real numbers we use the convention That we always select the positive root. For square roots of negative numbers that can't apply so we need a different convention. that typically means it selects the root that lies within a designated set of two consecutive quadrants of the complex plane. That makes such a sqrt function discontinuous at the places in the domain that map to the boundary of that region of the range.
It looks like Mathematica is using the 1st and 4th quadrants, ie requiring the argument to lie in the range ##(-\pi/2, \pi/2]##. That makes its square root function discontinuous at the negative x axis, as that maps to the negative y axis that is the omitted boundary of the selected half plane.
For your case with small ##a##, the item inside the sqrt sign approaches -1 as a goes to zero, so the discontinuous sqrt function gives a discontinuity there.
It's easily fixed by selecting the other square root: ##10^{-20}+i##, which is very close to ##i##.
EDIT: Just when I posted it, I saw that @FactChecker posted essentially the same thing just before me (only more concisely)!
EDIT2: If you instead adopt a square root function that always selects the square root lying in quadrant 1 or 2 (more specifically: the root's argument lying in ##(0,\pi]##) , your function will be continuous, because that sqrt function's discontinuity lies on the positive x axis, which is not in the image of the expression inside the square root sign.
Likes thatboi and FactChecker
Isn't there an issue too, of how calculators rounding of, accuracy breaking down at such small numbers?
Likes FactChecker
Good point. Those types of small problems near the discontinuity of a branch cut would cause large discontinuities.
thatboi said:
Hey all,
For real a, in the principal branch this is <br /> f(a) = \sqrt{\frac{(a-i)^2}{1 + a^2}} = \begin{cases}<br /> \frac{-a + i}{\sqrt{1 + a^2}} &amp; a \leq 0 \\<br /> \frac{a - i}{\sqrt{1 + a^2}} &amp; a &gt; 0. \end{cases} You can see that <br /> \lim_{a \to 0^{-}} f(a) = f(0) = i \neq -i = \lim_{a \to 0^{+}} f(a).
In general, yes. But here from the exact result above you can see that the only inaccuracy in the numerical result of 10^{-20} - i comes from taking \sqrt{1 + 10^{-40}} \approx \sqrt{1 + 2^{-132.88}} to be exactly 1. In particular, the sign of the imaginary part is correct.
Likes FactChecker
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
