Continuous Bijection f:X->X not a Homeo.
In summary: I think we can say that this is a homeomorphism because if we change the topology so that every point is in one of the two sets, then the inverse map is continuous.
Bacle
662
Continuous Bijection f:X-->X not a Homeo.
Hi, All:
A standard example of a continuous bijection that is not a homeomorphism is the
map f:[0,1)-->S^1 : x-->(cosx,sinx) ; for one, S^1 is compact, but [0,1) is not,so
they cannot be homeomorphic to each other.
Now, I wonder if it is possible to do this for a continuous bijection of a space to itself,
(with different topologies if necessary) and, if it is possible from a space with itself ,
but a map g: (X,T)-->(X,T) , i.e., with the same topology for domain and codomain.
Yes. Let X be the integers with the topology created by declaring a set to be open if either it is a subset of [itex]\mathbb{N}[/itex] or it is the entire set [itex]\mathbb{Z}[/itex]. Then the map [itex]f:X \rightarrow X : x \mapsto x-1[/itex] is a continuous bijection from X to itself, but it is not a homeomorphism, since the image of [itex]\mathbb{N}[/itex] is not open.
There are several other examples given on this stack exchange topic: http://math.stackexchange.com/quest...bijections-of-connected-spaces-homeomorphisms
changing the topology means it is no longer the same space. Take any set at all with more than one point and give it the topology with only two open sets, (the empty set and the whole space), and then give it the topology where every set is open. You can probably figure out which way the map is continuous.
It does seem however that every continuous bijection of a finite space with itself isa homeomorphism.
Citan: thanks for the link.
I am a bit confused; {1} is an open set , as a subset of N, but its preimage
is {0}, which is not, so I don't see how f is continuous.
Mathwonk: I guess the fewer the open sets, the smaller the chances
that some property will fail.
The preimage of {1} is {2}, not {0}.
It is quite easy to see that we can find such a map when we change the topology, but then the space doesn't really have anything to do with the other one, except having the same cardinality of its set of points. The question when the topology is the same though is interesting.
"It does seem however that every continuous bijection of a finite space with itself isa homeomorphism."Every bijective map from a compact space to a Hausdorff space is a homeomorphism. So we need one that is either non-compact or non-Hausdorff.
Usual examples of bijective maps that are not homeomorphisms involve "curling an infinity around" to join onto itself and form a loop, or some distinctive topological feature; maybe there is an example of a space where we can do this onto itself?
What about this?:
We have an infinite wedge of circles and real lines (all wedged at the same point). Let's say countably infinite.
Our map maps the first circle to the second, the second to the third... our 2nd line to the first, our 3rd to the 2nd... and out 1st line wraps around the 1st circle.
I reckon this will do the trick!
Sorry, I meant to say "half real lines" i.e. [0,\infty). So we have an infinite wedge of circles with an infinite number of infinitely long "sticks" coming out (haha!). We can curl one of the lines around one of the circles, like in your original example of a bijective continuous map which isn't a homeomorphism, and shift all the rest so that the map of the whole space is bijective and continuous onto itself, but the inverse map won't be continuous, since we are "splitting apart" close points on one of the circles.
it's interesting to find a pair X,Y of homeomorphic topological spaces and a continuous biyection f:X -> Y that is not homeomorphism. An answer to this question is the following:
Consider [itex]X=Y= \mathbb{R} - \cup_{\text{k odd positive}} \left[k,k+1 \right) [/itex] and [itex]f:X\rightarrow X[/itex] diven by
[tex]f(x)=\begin{cases} x/2 & \text{if } x \in \left[ 0,1 \right) \\
(x-1)/2 & \text{if } x\in \left[ 2,3 \right) \\ x-2 & \text{otherwise} \end{cases}[/tex]
You can see that f is continuous in X, and f^-1 is not in x=1/2.
That's a really nice example! (and probably a bit easier to visualise than mine).
Related to Continuous Bijection f:X->X not a Homeo.
1. What is a continuous bijection?
A continuous bijection is a function between two mathematical spaces that is both one-to-one and onto, and preserves the topological structure of the spaces. In simpler terms, it is a function that is both injective (no two elements in the domain map to the same element in the range) and surjective (every element in the range has at least one corresponding element in the domain), and also maintains the concept of "nearness" between points.
2. What is the difference between a continuous bijection and a homeomorphism?
A homeomorphism is a special type of continuous bijection that is also a topological isomorphism, meaning it preserves not only the topological structure but also the algebraic structure of the spaces. In other words, a homeomorphism not only maintains "nearness" between points, but also the operations and properties of the spaces, such as addition, multiplication, and continuity.
3. Why is a continuous bijection not necessarily a homeomorphism?
A continuous bijection may fail to be a homeomorphism if it does not preserve the algebraic structure of the spaces. For example, if a function is continuous but not differentiable, it cannot be a homeomorphism between differentiable spaces. In other cases, a continuous bijection may not be a homeomorphism because it is not invertible, meaning there is no inverse function that preserves both the topological and algebraic structures.
4. Can a continuous bijection be a homeomorphism if the domain and range are different spaces?
Yes, a continuous bijection can be a homeomorphism even if the domain and range are different spaces. The key requirement for a homeomorphism is that the function is both one-to-one and onto, and preserves the topological and algebraic structures of the spaces. As long as these criteria are met, the specific spaces do not matter.
5. Are there any examples of continuous bijections that are not homeomorphisms?
Yes, there are many examples of continuous bijections that are not homeomorphisms. One simple example is the function f(x) = x^3, which is a continuous bijection between the real numbers and itself, but is not a homeomorphism because it is not differentiable at x = 0. Another example is the function f(x) = 1/x, which is a continuous bijection from the positive real numbers to themselves, but is not a homeomorphism because it is not continuous at x = 0.
