MHB Continuous Functions - Thomae's Function ....
Math Amateur
MHB
I am reading "Introduction to Real Analysis" (Fourth Edition) b Robert G Bartle and Donald R Sherbert ...
I am focused on Chapter 5: Continuous Functions ...
I need help in fully understanding an aspect of Example 5.1.6 (h) ...Example 5.1.6 (h) ... ... reads as follows:
View attachment 7262In the above text from Bartle and Sherbert, we read the following:
" ... ... There are only a finite number of rationals with denominator less than $$n_0 $$in the interval $$( b - 1, b + 1)$$. (Why? ) ... ... Can someone explain to me why the above statement holds true?Help will be appreciated ... ...
Peter*** EDIT ***
... oh ... just realized that if denominator has to be less than $$n_0$$ then there can only be, at most, $$n_0 -1$$ of these rational numbers ... that is ... a finite number! ... ... ... Is that correct!
Peter
Suppose that $k$ is a positive integer less than $n_0$. The distance between consecutive rational numbers with denominator $k$ is $1/k$. So there at most $k$ such numbers in an interval of length $1$. Therefore there are at most $2k$ such numbers in the interval $(b-1,b+1)$, which has length $2$.
Thus for each of the finitely many numbers $k$ ($1\leqslant k\leqslant n_0$) there are only finitely many rational numbers with denominator $k$ in the interval $(b-1,b+1)$. But a finite union of finite sets is finite. Thus there are only finitely many rational numbers with denominator $\leqslant n_0$ in the interval $(b-1,b+1)$.
Hmm ... really interesting ...
Required a more thoughtful analysis than my first intuitive reaction ...:( ...
Thanks for the help ... enables me to see what is required in analysis ...
Peter
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
