MHB Continuous joint probability density functions
The discussion focuses on calculating the constant 'a' for a joint probability distribution function defined as a(x + y^2) within the bounds 0 <= x <= 2 and 0 <= y <= 2. The integral of this function must equal one to ensure it is a legitimate probability distribution. Participants discuss setting up the double integral and using tools like Integral Calculator to evaluate it, with one user suggesting the result is 28/3, leading to a proposed value of 3/28 for 'a'. Additionally, the conversation touches on deriving the marginal probability density function of Y and calculating the probability for the range 0.25 < Y < 0.75. The importance of understanding double integrals in this context is emphasized, indicating that familiarity with these concepts is crucial for solving such problems.
das1
Consider the following joint probability distribution function of (X , Y):
a(x + y^2) {0<=x<=2, 0<=y<=2}
0 otherwise
Calculate the value of the constant a that makes this a legitimate probability distribution. (Round your answer to four decimal places as appropriate.)
And then,
For the distribution above, determine the marginal probability density function of Y and use it to calculate the probability that 0.25 < Y < 0.75. (Round your answer to the fourth decimal place as appropriate.)
Mathematics news on Phys.org
What have you tried so far? What properties of joint probability distribution functions do you know? There is one property that was used in a thread you made yesterday which is useful here, just extended to two variables.
OK so this is what I've done:
I set up the integral from 0 to 2 of (x+y^2)dx dy = 1
I've never done an integral with 2 variables before but I plugged it into this calculator:
Integral Calculator - Symbolab
and it gave me 28/3 ? Set that = 1 and divide and get 3/28?
That's my best guess so far, but I could be way off.
You've never worked with double integrals before? Do you know how to solve something like this?
$$\int_{0}^{1} \int_{1}^{5} x+ydydx$$
If not you haven't been given the tools you need to solve this problem so it's totally understandable why this is difficult! :)
You are on the right track though in your reasoning. The double integral of the joint pdf should equal one:
$$\int_{0}^{2} \int_{0}^{2} a(x+y^2)dydx=1$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
