Continuous mappings into a Hausdorff space
In summary, the conversation discusses a problem in mathematics involving continuous functions and a Hausdorff space. The goal is to prove that a certain set is closed in X. The solution involves taking the complement of the set and showing it is open using disjoint neighborhoods. The set is then shown to be closed by using the fact that X\S can be written as a union of open sets. The conversation also briefly mentions the use of the inclusion property.
radou
3,149
Here's another one I'd like to check.
Let f, g : X --> Y be continuous functions into a Hausdorff space Y. Show that S = {x in X : f(x) = g(x)} is closed in X.
Let X\S be the complement of S in X. Let's show it's open.
Let x be an element of X\S = {x in X : f(x)[tex]\neq[/tex]g(x)}. For f(x) and g(x), choose disjoint open neighborhoods U and V, respectively. Now, f^-1(U)[tex]\cap[/tex]f^-1(V) is an open neighborhood of x which is contained in X\S. Since X\S can be written as a union of such open sets, it is itself open. Hence, S is closed.
Let's take it step by step (like the series... (-:).
you take x in X\S, which means we have y1=f(x), y2=g(x) which are distinct, now you use Ys haussdorfian, and you take two sets U and V which are disjoint neighbourhoods of y1 and y2 respectively, x is contained in the intersection of f^-1(U) and g^-1(V) (and not both with f^-1), now because f and g are continuous f^-1(U) and g^-1(V) are open in X.
so you showed that X\S is contained in a union of the above open sets, now show the other inculsion, well it's kind of basic as well.
Thanks for the reply.
I don't see why I should "use the other inclusion", since I managed to represent X\S as a union of its subsets "over all elements of X\S".
Yes, "f^-1" appeared twice - it was a mistype.
FAQ: Continuous mappings into a Hausdorff space
What is a continuous mapping into a Hausdorff space?
A continuous mapping into a Hausdorff space is a function between two topological spaces where the preimage of any open set in the target space is an open set in the domain space and the preimage of any point in the target space is a closed set in the domain space. The target space, also known as a Hausdorff space, is a topological space in which any two distinct points have disjoint open neighborhoods.
How is continuity defined in a continuous mapping into a Hausdorff space?
Continuity in a continuous mapping into a Hausdorff space is defined by the preservation of open sets. This means that for any open set in the target space, the preimage of that set in the domain space must also be open.
What is the importance of Hausdorff spaces in continuous mapping?
Hausdorff spaces are important in continuous mapping because they provide a stronger notion of separation between points. This allows for more precise and well-defined continuity conditions, making it easier to study and characterize continuous functions.
Can a continuous mapping into a Hausdorff space be defined between non-Hausdorff spaces?
Yes, a continuous mapping can be defined between non-Hausdorff spaces, but the resulting function may not be continuous. In order for a mapping to be continuous into a Hausdorff space, both the domain and target spaces must be Hausdorff.
How are Hausdorff spaces related to other topological properties?
Hausdorff spaces are related to other topological properties such as compactness and connectedness. For example, every compact Hausdorff space is also connected, and every connected Hausdorff space is also path-connected. Additionally, Hausdorff spaces are often used in the definition of other topological properties, such as normality and paracompactness.
