theone
- 81
theone said:Homework Statement
Can someone explain why f(x) = 1/(b-a) for a<x<b ?
shouldn't it be 0? since its a continuous random variable and so that interval from a to b has an infinite number of possible values?
Ray Vickson said:What do YOU think ##f(x)## means in this context? (Perhaps you are mis-interpreting the symbols, etc.)
Diegor said:The probability to get a particular value for X is 0 but if you want to know the probability to get X within a range, for example 3<X<4 you need to integrate the probability density between these two values and that is not always 0.
theone said:the probability that a continuous random variable X takes on one of its possible values x?
theone said:to get the probability of x falling within a range, aren't you essentially adding the probabilities of x taking on the particular values within the range... but if the probability of x taking on a particular value is 0, then why is this sum not always zero?
A continuous uniform distribution function is a probability distribution that describes the likelihood of a continuous random variable being within a certain range. It is also known as a rectangular distribution, as the probability density function is a flat line within the specified range.
The characteristics of a continuous uniform distribution function include a constant probability density function within a given range, a total area under the curve of 1, and equal probabilities for all values within the range.
A continuous uniform distribution function is used for continuous random variables, while a discrete uniform distribution is used for discrete random variables. In a continuous uniform distribution, the probability of any specific value is 0, while in a discrete uniform distribution, all values have equal probabilities.
The continuous uniform distribution function is commonly used in statistics and probability to model situations where all outcomes within a range are equally likely. This includes applications in finance, engineering, and physics.
To calculate probabilities using a continuous uniform distribution function, you need to know the range of values for the random variable and the specific value or range of values you are interested in. The probability is then calculated by finding the area under the curve within the specified range.
