Contort rectangle to torus minus splice=homomorphism?
In summary, the conversation discusses the possibility of a homomorphism or diffeomorphism in a transformation, specifically when excluding the edge splices. It is mentioned that this could be considered a "bending" and could potentially involve rotating matrices, but it is not clear how this would fit into the definitions of homomorphism and diffeomorphism. More context and clarification are needed to accurately answer the question.
aheight
321
109
I understand the transformation in general is not homomorphic but what about the transformation minus the splices, that is, contort it all the way up to and not including splicing the edges? Isn't that a homomorphism? Can't we define a bijective function (rotation matrices) to map the two spaces? Seems also to be diffeomorphism as well or no?
If you don't clue the edges, then it is only a "bending", which is both, homeomorph and diffeomorph (as long as you don't fold it somewhere).
Likes aheight
It is not clear what transformation you are referring to, so it is difficult to answer your question accurately. However, in general, a homomorphism is a structure-preserving map between two mathematical objects. It is not clear how rotating matrices would fit into this definition. Additionally, a diffeomorphism is a smooth, bijective map between two differentiable manifolds. Again, it is not clear how this would relate to the transformation you mentioned. Can you provide more context or clarify your question?
Related to Contort rectangle to torus minus splice=homomorphism?
1. What is a contorted rectangle?
A contorted rectangle is a two-dimensional shape that has been distorted or twisted in some way. It may have sides of varying lengths or angles that are not 90 degrees.
2. What is a torus?
A torus is a three-dimensional shape that resembles a donut. It has a circular cross-section and a hole in the middle. It can also be thought of as a three-dimensional version of a contorted rectangle.
3. What is a splice?
A splice is a mathematical term that refers to the process of joining two or more mathematical objects together. In this context, it is used to connect the contorted rectangle and torus in the equation.
4. What is a homomorphism?
A homomorphism is a mathematical function that preserves the structure of a mathematical object. In this case, it describes the relationship between the contorted rectangle and the torus, and how they are connected through the splice.
5. Why is this equation important?
This equation is important because it represents a fundamental concept in topology, which is the study of the properties of geometric shapes that are preserved under continuous deformations. It also has applications in various fields such as physics, computer graphics, and engineering.
