MHB Contour Integration: Calculating the Integral of $1/z$ with Residue Formula
  • Thread starter Thread starter Fermat1
    Integration
Fermat1
Calculate the integral of $1/z$ around $C$, where $C$ is any contour going from $-\sqrt{3}+i$ to $-\sqrt{3}-i$ and is contained in the set of complex numbers whose real part is negative.
My answer: Let $f=1/z$ Then $f$ has a simple pole at $z=0$ with residue 1. How do I calculate the winding number so I can use the residue formula?
Thanks
Thanks
Choose any contour that doesn't include z = 0. Maybe the semicircle to the left of these points centred at $\displaystyle \begin{align*} \left( -\sqrt{3} , 0 \right) \end{align*}$.
So the value depends on whether the contour encloses zero?
The contour CAN'T enclose z = 0 + 0i, surely you can see its real part is NOT negative.
So yes, the value of the integral will change if your contour contains this point. But you are told specifically to NOT include it.
ok sorry, I was a bit thrown by you saying to choose a contour. So in fact the integral is zero?
Thanks
Any path that leaves to the left point z = 0 is valid, so that you can choose a straight path. Setting $\displaystyle z= -\sqrt{3} + i\ t$ You have...
$\displaystyle \int_{C} \frac{d z}{z} = \int_{1}^{-1} \frac{d t}{- \sqrt{3} + i\ t} = i \ln \frac{\sqrt{3}- i}{\sqrt{3} + i}\ (1)$
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
I wanted to use cauchy's residue formula.
How can a contour that doesn't have any singular points in it possibly give any residue?
The basic concept is well understood observing the figure...View attachment 2771
It is required to compute the integral $\displaystyle \int_{A B} \frac{d z}{z}$ along a path located entirely in the left half-plane. Two possible paths are AB and ACB. But f(z) is analytic inside the triangle ABC so that is $\displaystyle \int_{A B C A} \frac{d z}{z} = 0$ and that means that the integral computed along the paths AB and ACB are the same, i.e. the value of the integral doesn't depend from the path if it located entirely in the left half plane. The most comfortable path is of course the straigh line AB...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
you should have factored in $z'=i$. So I get $ln(-{\sqrt{3}}-i)-ln(-{\sqrt{3}}+i)$. Can I use log laws even though its complex log? Cheers
Yes, You can! (Happy) ...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
So you admit you made a mistake? Regarding the subtraction law, Wikipedia says they may differ by a multiple of 2pi
Fermat said:
So you admit you made a mistake?...
Perhaps a more diplomatic approach would be:
"Was I correct in needing to factor in $i$?"
If Wikipedia says so ... what can we do as humans? (Tmi)...
Kind regards
$\chi$ $\sigma$
