jackthestudent
- 3
OP warned about not using the homework template
The Earth's magnetic field is cylindrically symmetric and can be described using cylindrical coordinates, (ρ,z,φ). The components of the magnetic field are given by:
(B_φ) = 0
(B_ρ) = −∂A/∂z,
(B_z) =(1/ρ) * ∂(ρA)/∂ρ.
The vector potential for a dipole field is given by
(A_φ) = (B_e)(ρ) * (R_e)^3/r^3
where B_e and R_e are the equatorial surface magnetic field strength and the radius of the Earth, respectively, and r is the radial distance from the center of the planet. Magnetic field lines are given by contours of a flux function F given by
F = ρ(A_φ).
The Earth's surface magnetic field at the equator B_e is 3,120 nT and its radius R_e is 6,371 km.
Using this information, create a contour plot of the Earth's magnetic field along a bisecting plane covering ρ<20R_e (it's symmetric, so the horizontal coordinate goes from -20R_e to +20R_e and −10R_e < z< 10R_e. Use the following steps:
1) Start by creating the coordinate grids for ρ and z, and the radius r. A grid cell size of ~0.02 R_e should be fine.
2) Compute the vector potential A and the flux function F.
Show the magnetic field lines (which are contours of F, computed from A as shown above) in a plot using about 5 or so black lines roughly equally spaced at the equator.
I have created 2 arrays, one for rho and one for z and then I have turned them into a 2D array in the form of F, the flux function. This is what I have entered into the interpreter:
Re = 6371000
rho = np.linspace(-20*Re, 20*Re, 2000)
z1 = np.linspace(-10*Re, 10*Re, 2000)
z = z1[:, np.newaxis]
Be = 3120*10**(-9)
F = (rho**2)*Be*(Re/np.sqrt(rho**2 + z**2))**3
plt.contour(rho, z1, F)
It returns a contour map with one dot on zero and nothing else even though there should be several contours. I can't figure out what I've done wrong or what to try next? Any help would be greatly appreciated :)
(B_φ) = 0
(B_ρ) = −∂A/∂z,
F = ρ(A_φ).
Re = 6371000
Be = 3120*10**(-9)
