Contraction constant in banach contraction principle
In summary: In the proof of the Banach Fixed Point Theorem, at least, the fact that $h<1$ is required in a particular step of the proof. If $h=1$, you don't get convergence of the sequence generated, as you mentioned above.How "h" be strictly less than 1 gave control over the rate of convergence of ${f}^{n}\left({x}_{0}\right)$ to the fixed point ?
ozkan12
149
İn some fixed point theory books, I saw an expression...But I didnt understand what this mean...Please can you help me ?
" It was important in the proof of banach contraction principle that the contraction constant "h" be strictly less than 1. Than gave us control over the rate of convergence of ${f}^{n}\left({x}_{0}\right)$ to the fixed point since ${h}^{n}\to0$ as $n\to\infty$. If we consider f is contractive mapping instead of a contraction, then we lose that control and indeed a fixed point need not exist.
How we lose control if we consider f is contractive mapping instead of a contraction ?
Please can you explain these questions ? Thank you so much...Best wishes...
So, the main difference, as I see it, between a contraction and a contractive mapping, is that with a contraction $A$,
$d(Ax,Ay)$ is strictly bounded away from $d(x,y)$ via the contraction constant, whereas with a contractive mapping $B$, $d(Bx,By)$ can be arbitrarily close to $d(x,y)$. While it's true that $d(Bx,By)<d(x,y)$, there's nothing preventing the LHS from being arbitrarily close to the RHS. Consequently, the convergence of the sequence of iterates can be much slower, and you might lose it altogether. As a result, guaranteeing a fixed point for a contractive mapping requires more assumptions. Here's an illustrative paper proving some fixed point theorems regarding contractive mappings. You can see that you need more hypotheses than with a contraction.
Dear professor,
What is LHS and RHS ?
Also, how "Consequently, the convergence of the sequence of iterates can be much slower, and you might lose it altogether." ?
And why If h=1, we don't get convergence of the sequence generated ?
LHS = Left Hand Side, and RHS = Right Hand Side.
From pages 300 to 302 in Introductory Functional Analysis with Applications, by Erwin Kreyszig:
5.1-2 Banach Fixed Point Theorem (Contraction Theorem).
Consider a metric space $X=(X,d),$ where $x\not= \varnothing$. Suppose that $X$ is complete and let $T:X \to X$ be a contraction on $X$. Then $T$ has precisely one fixed point.
Proof. We construct a sequence $(x_n)$ and show that it is Cauchy, so that it converges in the complete space $X$, and then we prove that its limit $x$ is a fixed point of $T$ and $T$ has no further fixed points. This is the idea of the proof.
We choose any $x_0 \in X$ and define the "iterative sequence" $(x_n)$ by
$$(2) \qquad x_0, \quad x_1=Tx_0, \quad x_2=Tx_1=T^2x_0, \quad \cdots, \quad x_n=T^n x_0, \quad \cdots.$$
Clearly, this is the sequence of the images of $x_0$ under repeated application of $T$. We show that $(x_n)$ is Cauchy. By [the definition of contraction with contraction constant $0\le \alpha<1$] and (2),
\begin{align*}
d(x_{m+1},x_m)&=d(Tx_m,Tx_{m-1}) \\
&\le \alpha d(x_m,x_{m-1}) \\
&= \alpha d(Tx_{m-1},Tx_{m-2}) \\
&\le \alpha^2 d(x_{m-1},x_{m-2}) \\
\cdots &\le \alpha^m d(x_1,x_0).
\end{align*}
Hence by the triangle inequality and the formula for the sum of a geometric progression we obtain for $n>m$
\begin{align*}
d(x_m,x_n)&\le d(x_m,x_{m+1})+d(x_{m+1},x_{m+2})+\cdots +d(x_{n-1},x_n) \\
&\le (\alpha^m+\alpha^{m+1}+\cdots+\alpha^{n-1}) \, d(x_0, x_1) \\
&=\alpha^{m} \, \frac{1-\alpha^{n-m}}{1-\alpha} \, d(x_0, x_1).
\end{align*}
Since $0\le \alpha <1$, in the numerator we have $1-\alpha^{n-m}<1$. Consequently,
$$(4) \qquad d(x_m,x_n)\le \frac{\alpha^m}{1-\alpha} \, d(x_0,x_1) \qquad (n>m).$$
On the right, $0\le \alpha<1$ and $d(x_0,x_1)$ is fixed, so that we can make the right-hand side as small as we please by taking $m$ sufficiently large (and $n>m$). This proves that $(x_m)$ is Cauchy. Since $X$ is complete, $(x_m)$ converges, say, $x_m \to x$. We show that this limit $x$ is a fixed point of the mapping $T$.
And the proof continues. As you can see, we use the fact that $\alpha<1$ to obtain the fact that the geometric series converges. It is simply a fact that a geometric series diverges if $\alpha=1$, in this context. As the proof hinges on this fact, not having $d(Tx,Ty)$ strictly bounded away from $d(x,y)$ has important implications for whether the operator $T$ has a fixed point. I suppose it might have a fixed point, anyway, but the Banach Fixed Point Theorem would not guarantee it.
FAQ: Contraction constant in banach contraction principle
What is the Banach contraction principle?
The Banach contraction principle, also known as the Banach fixed point theorem, is a fundamental theorem in the field of functional analysis. It states that if a mapping between a metric space and itself satisfies a certain condition, known as a "contraction", then it has a unique fixed point. This theorem is widely used in various areas of mathematics and engineering.
What is a contraction?
In simple terms, a contraction is a mapping that brings points closer together. More specifically, a mapping f from a metric space X to itself is a contraction if there exists a constant k (known as the contraction constant) such that for all x and y in X, the distance between f(x) and f(y) is less than or equal to k times the distance between x and y. In other words, the mapping shrinks distances between points by a factor of k.
What is the significance of the contraction constant?
The contraction constant plays a crucial role in the Banach contraction principle. It determines the rate at which the mapping contracts distances between points. A smaller contraction constant indicates a stronger contraction, meaning that the mapping brings points closer together at a faster rate. This is important because it ensures the existence and uniqueness of a fixed point, as guaranteed by the Banach contraction principle.
How is the contraction constant calculated?
The contraction constant is typically calculated using the Lipschitz constant of the mapping. The Lipschitz constant is a measure of how much a mapping can stretch distances between points. The contraction constant is then simply the Lipschitz constant divided by a factor of 2. In some cases, the contraction constant can also be calculated directly from the expression of the mapping.
What are some applications of the Banach contraction principle?
The Banach contraction principle has numerous applications in mathematics, engineering, and other fields. It is used to prove the convergence of various numerical methods for solving equations and systems of equations. It also has applications in optimization, control theory, and dynamical systems. In addition, the Banach contraction principle is a fundamental tool for proving the existence and uniqueness of solutions in various mathematical models.
