Contradicting solutions to a basic movement problem.
In summary: I don't understand why the first solution I tried doesn't work, but the second solution does. I'll look more into vector analysis and try to figure out what's going on.In summary, the problem asks for the rate of change of the distance between two particles moving in opposite directions. The first solution uses vectors, but the second solution uses differentiation, and the results are the same.
Adgorn
130
Hi, everyone. I came across a basic calculus problem concerning movement of 2 problems, I've attempted to solve it using vector analysis and got 1 answer, and then solved it with differentiation and got a different answer. I'll show a version of it I made which is a bit more simplified to make things easier since even then the same problem occurs:
"Particle A moves along the positive horizontal axis, and Particle B moves along the positive vertical axis. At a certain time, the A is at the point ##(5,0)## and moving with speed 3 units/sec; and B is at the point ##(0,3)## and moving with speed 4 units/sec. At what rate is the distance between A and B changing?"
Pythagorean theorem, chain rule.
Intuitively, this is just a "riverboat problem", the rate of change of the distance between A and B at a certain moment is just their speed relative to each other at that moment, and does not depend on their location. To get this relative speed you just have to add the velocity vectors. I have the feeling that this intuition is the fault in my calculation, although I don't realist why, which would explain why the first method produces a wrong answer:
Method 1, vectors: The particles move away from each other with a horizontal speed of 3 units/sec and a vertical speed of 4 units/sec. Thus, the speed at which they move away from each other is ##\sqrt {3^2+4^2}=5## units/sec.
Method 2, differentiation: Let the position of A be ##(a(t),0)##, the position of B be ##(0,b(t))##, the distance between A and B be ##d(t)## and the specified time of the problem be ##t_0##. Then ##a(t_0)=5##, ##a'(t_0)=3##, ##b(t_0)=3## and ##b'(t_0)=4.##
At any moment ##t##, ##d(t)^2=a(t)^2+b(t)^2##, so ##d(t_0)=\sqrt {25+9}=\sqrt {34}##. Differentiating the 2 sides of the equation yields
##2d(t)d'(t)=2a(t)a'(t)+2b(t)b'(t)## or ##d'(t)=\frac {2a(t)a'(t)+2b(t)b'(t)} {2d(t)}##, inserting the values at ##t_0## yields ##d'(t)=\frac {30+24} {2\sqrt {34}}=\frac {27} {\sqrt {34}}##.
The book uses the 2nd method, so I assume something is wrong with the 1st method, probably something very basic that I looked over. The equations of the 2nd method seem to indicate that the relative velocity does depend on the location of the particles, which is something I don't quite understand. Clarification would be very appreciated.
The velocity vector is not in the same direction as the distance vector, so its magnitude doesn't directly represent the rate at which the distance is changing.
The wrong concept is related to direction. In first case,we found relative velocity as seen by first observer. What question says is find relative velocity in the direction of rod. And,indeed you get result. The velocity vector components along the direction of rod are :
$$4 \cos\theta $$ and $$ 3\sin\theta$$. The relative velocity is:
$$4\cos\theta + 3\sin\theta$$. After substituting required values,we get the same answer as in second method
You'll have to forgive me for my slow understanding, I haven't actually got into vector analysis at this point, but I used it here since it matches my (evidently wrong) intuition about the problem. I'll explain my intuition:
Both particles move at a constant velocity in a straight line, so from the point of view of each particle, the other particle must see the other one moving at a constant speed in a straight line. The rate of change of the distance between them is just the (absolute value of) velocity of one particle relative to the other one, say, the velocity of particle B from the point of view or particle A.
If particle B moves ##x## units away from particle A during ##t## seconds, the distance grows by ##x## units during ##t## seconds. Since particle A needs to see particle B moving at a constant speed in a straight line, the rate of change of the distance should be constant at all times, and can't depend on the position of the particles. Yet 2 immediate problems stem from this intuition.
1. The absolute value of the relative velocity of particle B with respect to A, 5 units/sec, is not the rate of change of the distance.
2. The actual rate of change of the distance does depend on the location of the particles, even though they are moving at the same speed and at the same direction. This seems to completely contradict my intuition about inertial reference frames. If the rate of change of the distance is how fast the particles move away from each other, and their frames is inertial, the rate at which they move away from each other needs to be constant too.
Obviously, I'm missing something basic here...
Adgorn said:
You'll have to forgive me for my slow understanding, I haven't actually got into vector analysis at this point, but I used it here since it matches my (evidently wrong) intuition about the problem. I'll explain my intuition:Both particles move at a constant velocity in a straight line, so from the point of view of each particle, the other particle must see the other one moving at a constant speed in a straight line. The rate of change of the distance between them is just the (absolute value of) velocity of one particle relative to the other one, say, the velocity of particle B from the point of view or particle A.If particle B moves ##x## units away from particle A during ##t## seconds, the distance grows by ##x## units during ##t## seconds. Since particle A needs to see particle B moving at a constant speed in a straight line, the rate of change of the distance should be constant at all times, and can't depend on the position of the particles. Yet 2 immediate problems stem from this intuition.1. The absolute value of the relative velocity of particle B with respect to A, 5 units/sec, is not the rate of change of the distance.2. The actual rate of change of the distance does depend on the location of the particles, even though they are moving at the same speed and at the same direction. This seems to completely contradict my intuition about inertial reference frames. If the rate of change of the distance is how fast the particles move away from each other, and their frames is inertial, the rate at which they move away from each other needs to be constant too_Obviously, I'm missing something basic here...
Using your vector approach you got a constant answer of ##5## units per second. Let's look at this.At ##t =0## they are at ##(0,3)## and ##(5,0)##, which are ##\sqrt{34}## units apart.
At ##t =1## they are at ##(0,7)## and ##(8, 0)##, which are ##\sqrt{119}## apart.
If you do the calculation you'll see that these distances do not differ by ##5## units.
Nevermind, I understood what my problem was. I thought that from the point of view of particle A, particle B was moving directly away from it (i.e. in a straight line that goes through the center of the reference frame), though it didn't, so the rate of change of the distance is not the relative speed of particle B. Thanks for the help.
Related to Contradicting solutions to a basic movement problem.
1. What is a basic movement problem?
A basic movement problem refers to a situation where an object or organism needs to move from one point to another, but there are constraints or obstacles that make it difficult to do so.
2. What are contradicting solutions?
Contradicting solutions are different ways of solving a problem that produce conflicting or opposite results. In the context of a basic movement problem, this could refer to different strategies or techniques for overcoming the constraints, but each solution may have its own drawbacks or limitations.
3. Why are there contradicting solutions to a basic movement problem?
Contradicting solutions can arise due to the complexity of the problem itself and the diverse range of factors that can influence movement. Additionally, different individuals or groups may have varying perspectives or approaches to the problem, leading to contradictory solutions.
4. How do scientists determine which solution is best?
Scientists use a combination of experimentation, observation, and analysis to evaluate the effectiveness of different solutions to a basic movement problem. They may also consider factors such as efficiency, safety, and sustainability to determine the most optimal solution.
5. Can contradicting solutions be combined to create a better solution?
Yes, scientists often explore the possibility of combining contradicting solutions to create a more comprehensive and effective solution. This approach, known as synthesis, can lead to innovative and improved methods for solving basic movement problems.
  • Differential Equations
