I Contrapositive of theorem and issue with proof
  • I
  • Thread starter Thread starter psie
    Logic
The discussion revolves around the contrapositive of a theorem stating that if a continuous function maps a connected space to another space, the image is also connected. The confusion arises regarding whether the continuity of the function should be included when taking the contrapositive. It is clarified that the contrapositive of the theorem is: if the image is not connected, then the function is not continuous. The participants explore different interpretations of the contrapositive, emphasizing that the definitions and logical structures can lead to varying conclusions. Ultimately, the validity of the original proof is questioned based on the interpretation of continuity in the context of the contrapositive.
psie
TL;DR Summary
I'm stuck on a contrapositive of a theorem and a logical issue with a proof. It concerns the statement that the image of a connected set is connected under a continuous map.
Consider the following theorem:
Theorem Suppose that ##f:X\to Y## is a continuous map between two topological spaces ##X## and ##Y##. Then ##f(X)## is connected if ##X## is.
First, I don't know how to take the contrapositive of this statement. I'm not sure if the opening hypothesis, that is, ##f## is continuous, remains outside. Because the way this is proved in the text I'm reading is by assuming ##f(X)## is disconnected and then using continuity to show that ##X## is also disconnected. Since the author uses the continuity assumption, it seems like that is not a part of the statement that one takes the contrapositive of.
Yet, I saw someone claim,
Claim If a function has a connected domain ##X## and a disconnected range ##f(X)##, then the function is not continuous on ##X##.
So in this claim it seems like that the continuity is actually negated as well. I'm confused and I'm now doubting the validity of the proof of the theorem. What is correct and what isn't?
A: A function f(X) is a continuous map between two topological spaces X and f(X)
B: f(X) is connected
C: X is connected
If C and Not B, then Not A.
So the original sentence is When A: Then B, if C.
This can be rewritten: If A, then (if C then B)
The contrapositive: If not (if C then B) then not A.
(if C then B) is false only when C is true and B is false
so: not (if C then B) == ( C and not B)
Thus: If not (if C then B) then not A == if (C and not B) then not A
QED
The theorem itself is of the form:
Suppose ##f## is continuous, then property A holds.
The contrapositive of that is:
If property A does not hold, then ##f## is not continuous.
That's probably the answer for the contrapositive of the theorem.
In this case, property A is also an "if-then":
If ##X## is connected, then ##f(X)## is connected.
The contrapositive of property A is:
If ##f(X)## is not connected, then ##X## is not connected. But, that's not the contrapositive of the theorem.
Hmm, ok. I'm still uncertain about that proof. Is it correct to use the continuity of the function when proving the contrapositive of the theorem?
What I said was that there is a difference between the contrapositive (statement) of the theorem and the contrapositive (statement) of a condition or property used in the theorem.
In that sense, we are arguing about a definition of what precisely the contrapositive means in this case. There's no error in either argument that is not based on an interpretation of the question.
Let ##A##, ##B## and ##C## be propositions. Then the following formulas are equivalent.
\begin{align*}
&A\to (B\to C)\\
&A\land B\to C\\
&B\to (A\to C)\end{align*}Therefore there are many ways to construct equivalent statements using contrapositive. Below ##F\equiv G## means that ##F## and ##G## are equivalent.
\begin{align*}
A\to (B\to C)&\quad\equiv\quad\neg(B\to C)\to\neg A&&\equiv\quad B\land\neg C\to\neg A\tag{1}\\
A\to (B\to C)&\quad\equiv\quad A\to(\neg C\to\neg B)\tag{2}\\
A\land B\to C&\quad\equiv\quad\neg C\to\neg(A\land B)&&\equiv\quad\neg C\to\neg A\lor\neg B\tag{3}\\
B\to (A\to C)&\quad\equiv\quad\neg(A\to C)\to\neg B&&\equiv\quad A\land\neg C\to\neg B\tag{4}\\
B\to (A\to C)&\quad\equiv\quad B\to(\neg C\to\neg A)\tag{5}\end{align*}Usually contrapositive is applied when the assumption and the conclusion of the implication are atomic rather than compound propositions. This means that proving formulas at the end of lines (1) and (4) is somewhat unusual but still valid way to prove ##A\to(B\to C)##. I believe a more common way is to leave one of the assumptions ##A## or ##B## unchanged and then take the contrapositive of the remaining implication as in lines (2) and (5).
In this situation if we denote "##f## is continuous" by ##A##, "##X## is connected" by ##B## and "##f(X)## is connected" by ##C##, then the text proved formula in (2). The second claim in post 1 is (1).
Likes psie and PeroK
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
