Control system with equation C = A*x + B*dx/dt
In summary: Actually, I'm not a Physics student, so I don't really know, but I'd guess it's the exponential delay. So if B doubles then the constant becomes half, thus the half-life becomes double. Is this correct?In summary, the steady state of a control system described by the equation C = A*x + B*dx/dt does not change when the mass of the robot is doubled, as it occurs when dx/dt is 0 and B does not affect the solution. However, the half-life of the system decreases, as shown by the equation -B/A*ln(x) = c*t + k1, where x = xoe-ACt/B and xo = e-kA/B. This can be explained
zsero
This question came up in a computer science / robotics exam and I still don't know the solution for it. I figured out that it's classical mechanics related, so I thought this might be the best place to ask it.
Suppose a control system is described by the equation C = A*x + B*dx/dt, where B is proportional to the mass of the robot. The behaviour of the system can be characterised by the steady state (e.g. the asymptotic velocity of the robot) and the half-life time of the decrease of the distance to the steady state. Explain how the steady state and the half-life change if the mass of the robot is doubled.
C = A*x + B*dx/dt
I've figured out that the steady state doesn't change, as it happens when dx/dt is 0, thus B is not affecting the solution.
And this is how far I understand it. Can you explain to me, what kind of movement is this, what is the real-life meaning of the steady state and half-life for this movement and that how to calculate the change in the half-life?
hi zsero! :smile:
write it Bdx/dt = C - Ax, then solve it by "separating the variables" :wink:
tiny-tim said:
hi zsero! :smile:
OK, I arrive at the following equation:
My problem here is that I don't understand the meaning of the equations and that what is asked by half-life and steady state.
How can I get the half-time from this equation?
ok, now multiply by -1/B and then e-to-the on both sides …
x = xoe-ACt/B (where xo = e-kA/B)
does that look familiar? :wink:
Thanks for the help! Actually, I'm not a Physics student, so I don't really know, but I'd guess it's the exponential delay. So if B doubles then the constant becomes half, thus the half-life becomes double. Is this correct?
good guess! :smile:
but you really should make yourself familiar with half-life (and exponential decay generally) …
look it up in wikipedia or the pf library :wink:
FAQ: Control system with equation C = A*x + B*dx/dt
What is a control system?
A control system is a system that is designed to regulate or control the behavior of another system. It uses inputs, such as sensor readings or commands, to generate outputs that will influence the behavior of the controlled system.
What is the equation C = A*x + B*dx/dt used for?
This equation is used to represent a control system in which the output (C) is determined by a combination of the input (x) and the rate of change of the input (dx/dt). The coefficients A and B represent the weights given to the input and its rate of change, respectively, in determining the output.
What is the role of A and B in the control system equation?
The coefficient A represents the sensitivity of the output to changes in the input, while the coefficient B represents the sensitivity of the output to changes in the rate of change of the input. Together, they determine the overall influence of the input and its rate of change on the output of the control system.
How does a control system with equation C = A*x + B*dx/dt work?
A control system using this equation works by continuously monitoring the input and its rate of change, and using the coefficients A and B to determine the appropriate output. This output is then fed back into the system as a new input, and the process repeats in a closed loop until the desired behavior is achieved.
What are some common applications of a control system with equation C = A*x + B*dx/dt?
This type of control system is commonly used in various fields such as engineering, economics, and biology. Some specific applications include temperature control in HVAC systems, speed control in vehicles, and financial market analysis and prediction.
