Control Theory/flow of licuids in tanks - bernoully and Darcy
  • Thread starter ester_franke
  • Tags
    Control
In summary: Substituting this into the equation above, we get:a*sqrt(2gh1) = k*(0.5*L)Solving for k, we get:k = (2*a*sqrt(2gh1))/LNow we have all the information we need to find the transfer function and the "k" of the pipe. I hope this helps you with your homework. Good luck!In summary, we have a system with two tanks connected by a pipe. The height of tank 1 is the input and the height of tank 2 is the output. Using the principle of conservation of flow rate, we can derive the transfer function and use Darcy's formula to find the "
ester_franke
Two tanks with water, connected in the bottom by a pipe (known area (a) and length (L)). One of the tanks have known bottom area (A).
a= 0,03m
A= 1 m
L = 40 m
Input: hight of tank1 (h1)
Output: hight of tank2 (h2)
I am asked to:
- Draw block scheme (H1= tank1, H2=pipe, H3=tank2)
- Find the transference function
I am also told to use Darcy's formula (with level difference 0,5 m) to find the "k" of the pipe.
Formula Darcy (given by professor):
Q = k((0,5*A)/L)
First of all the Q at the bottom of the tanks will be:
q=a*srt(2gh) due to Bernoullli
I do a linealization and find my q(s)/h(s) = (-a/2)*srt((2g)/h_0)
I am thinking that the Q trough the pipe is constant. Therefore the two qs should be alike. However, that only states that the levels of the tank will be alike aswell, (which they off course will, but after a while).
However, after this I'm stuck. I've been trying for 1,5 weeks now! This is my first homework in control Theory ever, and it feels like I'm missing something..?!
Thanks a lot for your help.
//L
Dear L,
Thank you for your forum post. I would approach this problem by first drawing a block diagram, as suggested. This will help us visualize the system and understand the relationships between the different variables.
I have attached a sketch of the block diagram below. As you can see, the two tanks (H1 and H3) are connected by a pipe (H2). The input to the system is the height of tank 1 (h1) and the output is the height of tank 2 (h2).
To find the transfer function, we can use the fact that the flow rate through the pipe is constant. This means that the flow rate at the bottom of tank 1 (q1) is equal to the flow rate at the bottom of tank 2 (q2). We can express this mathematically as:
q1 = q2
Using the formula given by your professor, we can write:
k((0.5*A)/L) = a*sqrt(2gh2)
Where k is the "k" of the pipe, A is the bottom area of tank 1, L is the length of the pipe, a is the area of the pipe, g is the acceleration due to gravity, and h2 is the height of tank 2.
Solving for h2, we get:
h2 = (k^2*(0.5*A)^2*g)/(a^2*L^2)
Therefore, the transfer function is:
h2/h1 = (k^2*(0.5*A)^2*g)/(a^2*L^2)
To find the "k" of the pipe, we can use Darcy's formula, as you mentioned. This formula relates the flow rate through a pipe to the hydraulic gradient (the pressure difference divided by the length of the pipe). We can write this as:
Q = k*(i*L)
Where Q is the flow rate, k is the "k" of the pipe, i is the hydraulic gradient, and L is the length of the pipe.
In our case, the hydraulic gradient is 0.5 m (given by the level difference between the two tanks). So we can write:
Q = k*(0.5*L)
We know that the flow rate through the pipe is constant, so we can calculate it using the flow rate at the bottom of tank 1 (q1):
Q = q1 = a*
FAQ: Control Theory/flow of licuids in tanks - bernoully and Darcy
What is control theory and how does it relate to the flow of liquids in tanks?
Control theory is a branch of engineering and mathematics that deals with the analysis and design of systems that are affected by external inputs. In the context of the flow of liquids in tanks, control theory involves understanding how different variables such as flow rate, pressure, and level can be controlled to achieve a desired outcome.
What is Bernoulli's principle and how does it apply to the flow of liquids in tanks?
Bernoulli's principle states that as the velocity of a fluid increases, the pressure decreases. This principle applies to the flow of liquids in tanks as the velocity of the liquid increases, the pressure decreases, causing the liquid to flow faster through the tank.
What is Darcy's law and how does it impact the flow of liquids in tanks?
Darcy's law is an equation that describes the relationship between the velocity of a fluid, the cross-sectional area of the flow, and the pressure drop across the flow. It applies to the flow of liquids in tanks by helping to calculate the flow rate and pressure of liquids moving through a tank.
How does the shape and size of a tank affect the flow of liquids within it?
The shape and size of a tank can have a significant impact on the flow of liquids within it. A larger tank with a smaller cross-sectional area will result in slower flow due to greater friction. Additionally, the shape of the tank can affect the distribution of pressure and velocity within the tank, leading to variations in flow rate.
What are some common control strategies used in managing the flow of liquids in tanks?
Some common control strategies used in managing the flow of liquids in tanks include flow control valves, level controllers, and pressure regulators. These strategies involve adjusting the flow rate, level, or pressure of the liquid to achieve a desired outcome. Other strategies may include using pumps or altering the geometry of the tank to optimize flow.
