Controllable Force & Speed Linear Actuator
In summary: It would be worth doing some preliminary research to find the limits of the system you are intending to build before getting too far ahead in your design.In summary, the current system seems to cheat a little by using the pneumatics. The output force can be increased by increasing the pressure and the frequency of the actuator movement is dictated by a solenoid valve allowing air into either side of the cylinder chamber. Analysis shows that the speed of the stroke stays roughly the same despite the changing pressure.
Eubie
I am investigating linear actuator technologies as an alternate to using pneumatics. I require independent control over both the output force and stroke velocity. The force needs to be varied between 30-160N and the stroke velocity varied up to a maximum 1.2m/s. The maximum frequency of actuator movement should be 16Hz. The stroke length should ideally remain the same at about 15-20mm.
Any suggestions of anything that could provide this. I have been looking at electrical actuators but I don't know that its possible to independently control both the output force and speed.
I'd suggest dropping the concern for controlling force. Don't think of the actuator applying a specific force. The load will provide the force and the actuator will match it. You only need select one that has the ability to provide a safe margin over the max force provided by the load.
Output force and speed are related parameters that cannot be controlled Independantly. Pick one or the other to control, and let the other follow. I suggest speed.
Now you only have to consider required speed and controllability. You have many choices, but we would need to know more about the application to suggest more.
Thanks for the reply. The problem is that the current system seems to cheat a little by using the pneumatics. The output force can be increased by increasing the pressure and the frequency of the actuator movement is dictated by a solenoid valve allowing air into either side of the cylinder chamber. Analysis shows that the speed of the stroke stays roughly the same despite the changing pressure.
My task is to create a similar system and from what you have said it would be best if I could control the force output between 30-160N and if at all possible maintain a relatively steady stroke speed.
Your description is a little confusing.
  • Do you require an actuator to function as a ram or hammer, impacting an object with different speeds and/or forces? Then halting its motion?
  • Or more simply a device to push against an object with a specified speed and/or force?
In either case you could use a ballscrew affair with a rotary servo motor. Or perhaps more simply with a linear servo motor. With a reasonably sophisticated servo controller, you could monitor the motor current. The motor current is generally proportional to motor torque / force. It would require significant engineering to get everything sized properly and then calibrated for force/speed/current, but it could be done. I've done something similar: monitoring the linear servo motor current to detect contact with an object.
It is to be a ram that would impact an object with different speeds and forces. The piston would come out and impact at a specified force.
Would increasing the torque, which would generate a greater force, drastically reduce the stroke speed?
Not necessarily. Most likely you will only get a definitive answer for that question by examining a motor's speed/torque curve data.
Related to Controllable Force & Speed Linear Actuator
1. What is a controllable force and speed linear actuator?
A controllable force and speed linear actuator is a type of mechanical device that converts rotational motion into linear motion with the ability to control both the force and speed of the movement. It is commonly used in various applications such as robotics, manufacturing, and automation.
2. How does a controllable force and speed linear actuator work?
The actuator consists of a motor, a screw or belt mechanism, and a control system. The motor rotates the screw or belt, which converts the rotational motion into linear motion. The control system regulates the speed and force by adjusting the input to the motor, allowing for precise control of the actuator’s movement.
3. What are the advantages of using a controllable force and speed linear actuator?
One of the main advantages is the precise control it offers over the movement, allowing for accurate positioning and smooth motion. It also eliminates the need for additional mechanisms or components to control the speed and force, resulting in a more compact and efficient system. Additionally, it can handle heavy loads and operate at high speeds, making it suitable for a wide range of applications.
4. What are some common applications of controllable force and speed linear actuators?
Controllable force and speed linear actuators are commonly used in robotics, CNC machines, packaging equipment, medical devices, and other industrial automation systems. They are also used in home automation, such as in motorized blinds or adjustable furniture.
5. What should I consider when choosing a controllable force and speed linear actuator?
Some important factors to consider include the required force and speed, the stroke length, the power source, and the type of control system. It is also important to consider the durability and reliability of the actuator, as well as the manufacturer’s support and warranty. Consulting with a specialist or engineer can also help in selecting the right actuator for your specific application.
  • Mechanical Engineering
  • Electrical Engineering
  • General Engineering
15K
