Controller Design with Bode Plots
In summary, the book uses the forward loop gain to design a phase lead / lag controller. However, when compensating a process with a forward path, the book found the transfer function rather than the forward loop gain. I need to solve for a crossover frequency and the book says that I need a phase lag compensator. Unfortunately, I don't understand how to design this type of compensator.
paul2211
36
I have two questions. One theoretical, and one pertaining to the homework question below.
The theoretical question for which I am having trouble. When designing a controller to compensate a process using Bode Plots, why does my book seem to just use the forward loop gain rather than the transfer function (of an unity feedback system)?
i.e. For a forward path of Gc(s) and G(s) with unity feedback, the book's example seems to just overlay these two bode plots to meet the design requirements. Why did it not find the transfer function, and instead just uses the forward loop gain? (Or I am totally misunderstanding what my book does)
1. Homework Statement
Design a phase lead / lag controller so that G(jω) = 300,000/s(s+360) will have a Phase Margin (PM) of 60 degrees and have high frequency (ω >= 1000 rad/s) gain <= -20 dB
L(s) = Gc(s)G(s), where Gc(s) = K(s+z)/(s+p) as a Lead/Lag compensator
The picture of the control system I am referring to is: http://wps.prenhall.com/wps/media/objects/1468/1503802/ch10mc3.gif
Please ignore the equations as this is not the question I am doing.
Solving for ωcrossover using the uncompensated system:
0 ≈ 20log(833.333/(ω^2/360)
ω = 548 rad/s
Plugging into phase: Ang G(s) = 0 - 90 - atan(ω/360) = -146 degrees. PM uncompensated = -146 + 180 = +34 degrees.
Cannot use phase lead compensator with the phase peak at 548 rad/s because it will increase magnitude's gain at high frequencies. Uncompensated gain is at -13 dB at 1000 rad/s, so I must decrease high frequency gain.
This means I will need a phase lag compensator, which decreases the gain at high frequencies.
Now I am stuck. I cannot design a lag compensator at the original crossover ω = 548 rad/s because it will decrease the PM. So I essentially need to design something that will decrease the crossover frequency using the magnitude plot.
The way my professor does in class seems more like an art than science. I feel like this will need MATLAB to do. My prof hinted that these types of questions will be on the final, so are there any hints/systematic ways to design these controllers?
Thanks so much!
If ##G_f(s)## and ##H(s)## is everything in the forward and feedback path, respectively, then the open-loop function is defined as ##L(s) = G_f(s) H(s)##. In your case, you have:
L(s) = G_c(s) G(s), \quad G_f(s) = G_c(s) G(s), H(s) = 1
The gain and phase margin of ##L(s)## tells you something about how the open-loop system ##L(s)## behaves in closed loop. If you instead consider the gain and phase margin of the closed-loop system ##T(s) = \frac{G_f(s)}{1 + G_f(s) H(s)}##, then you're evaluating how ##T(s)## behaves if you put an outer feedback loop around this inner feedback system, i.e is the system ##\frac{T(s)}{1 + T(s)}## stable etc. You see the problem?
Does the assignment not mention any requirement on the crossover frequency? Otherwise, you could solve it by just lowering the gain.
If you could include a picture of the problem as it's given to you, that would be very helpful.
Edit:
If you're asked to maintain the uncompensated crossover frequency and raise the phase margin, then you can solve it by putting the lag part at a sufficiently low frequency.
Also, the lead-lag compensator has the zero/pole/gain form:
G_c(s) = \frac{K (s + z_1) (s + z_2)}{(s + p_1) (s + p_2)}
where ##z_1 < p_1## and ##z_2 > p_2##.
ω = 548 rad/s
If ##G(s) = \frac{300000}{s (s + 360)}##, then that crossover frequency isn't right. Could you include a bit more detail?
Wow! Thank you so much. That makes a lot of sense! So just to confirm, for a non unity feed back with ##H(s)##, I would still plot the Bode Plot with ##L(s) = G(s) G_c(s) H(s)## for finding GM and PM. And this just shows how the open loop Gc(s)G(s) behaves in a closed loop with feedback H(s)?
Also, do you have a suggestion of what to read to get a better, basic theoretical understanding of these things? My class and textbook isn't the best. I just know how to solve problems, but don't really understand what I am doing...
This helped for me. I just found on the phase plot where it matched my required PM, and put a lag compensator at very low frequency to change my crossover frequency to the required phase location!
Thanks a lot
paul2211 said:
So just to confirm, for a non unity feed back with H(s)H(s), I would still plot the Bode Plot with L(s)=G(s)Gc(s)H(s)L(s) = G(s) G_c(s) H(s) for finding GM and PM. And this just shows how the open loop Gc(s)G(s) behaves in a closed loop with feedback H(s)?
Yes, in terms of stability and performance, we're ultimately interested in coercing the closed-loop transfer function into some form, but it's usually not directly obvious how to accomplish that by manipulating the controller. One of the great accomplishments in the early days of feedback system analysis is that we can predict, usually very accurately, how the closed-loop system behaves by just looking at the open-loop function, which we can very easily see how is affected by the controller (using, for instance, Bode plots). That's also very important since we can determine the frequency response of the open-loop function experimentally, i.e. we can design control systems based on simple tests.
I can recommend the book "Feedback Control Systems" by Phillips and Harbor. In my opinion, it explains the fundamentals of feedback systems in a very approachable fashion. Books on control theory can quickly devolve into texts on applied mathematics, but this one takes care not to include too much unnecessary detail. It's still rigorous, but it doesn't overdo it.
Also, if you have any specific questions, you're welcome to post them here on PF in, for instance, the EE forum.
I can provide some insights into the use of Bode plots in controller design. Bode plots are commonly used in control systems because they provide a graphical representation of the frequency response of a system. This allows for a quick and intuitive understanding of the system's behavior and can aid in the design of controllers.
In the example you provided, the book is using the forward loop gain rather than the transfer function because the forward loop gain represents the open-loop response of the system. In other words, it shows the response of the system without any feedback. This is important because in control systems, the controller is designed to modify the open-loop response in order to achieve the desired closed-loop response. Therefore, it makes sense to use the forward loop gain in controller design.
As for the homework question, designing a phase lead/lag controller to meet specific design requirements can be a challenging task. There are a few approaches that can be used to design a controller using Bode plots. One approach is to use the root locus method, which involves plotting the poles and zeros of the system on the s-plane and analyzing their movement as the controller parameters are varied. Another approach is to use the Nyquist stability criterion, which involves plotting the frequency response of the system on a polar plot and determining the stability of the system based on its encirclement of the -1 point.
In terms of systematic ways to design controllers, there are various methods that can be used, such as the Ziegler-Nichols method or the Cohen-Coon method. These methods involve tuning the controller parameters based on the characteristics of the system, such as its time constant and gain. However, it is important to note that controller design is not always a straightforward process and may require some trial and error to achieve the desired response.
In conclusion, Bode plots are a useful tool in controller design, but they should be used in conjunction with other methods and techniques to design a robust and stable controller. It is also important to have a good understanding of the system dynamics and control theory principles in order to effectively design controllers. I recommend consulting with your professor or a control systems expert for further guidance and assistance in designing controllers.
Related to Controller Design with Bode Plots
1. What is a Bode Plot?
A Bode plot is a graphical representation of the frequency response of a system. It shows the magnitude and phase of a system's transfer function as a function of frequency.
2. Why is a Bode Plot used in controller design?
A Bode plot is used in controller design because it provides important information about the stability and performance of a system. It helps in selecting appropriate controller parameters to achieve desired system response.
3. How do you interpret a Bode Plot?
The magnitude plot of a Bode plot shows how the system responds to different frequencies, with higher peaks indicating higher magnitude. The phase plot shows the delay in response at different frequencies. Both plots can be used to determine the system's stability and performance.
4. What are the important features of a Bode Plot?
The important features of a Bode plot include the cutoff frequency, which is the frequency at which the magnitude starts to decrease. The gain crossover frequency, where the magnitude crosses 0 dB, and the phase margin, which indicates the stability of the system.
5. How do you use a Bode Plot in controller design?
To use a Bode plot in controller design, first determine the desired system response. Then, adjust the controller parameters to achieve the desired response based on the information from the Bode plot, such as the gain crossover frequency and phase margin. The Bode plot can also be used to identify any potential stability issues and make necessary adjustments to the controller design.
