Controlling optical wavelength of illumination to improve reproduction rates in microorganisms
metz
TL;DR Summary
reproduction, optics, wavelengths, light, sustainability, material, chemistry, earth sciences, microorganisms
hello!
I am trying to make a device that will improve reproduction rates in certain microorganisms that I am studying. They reproduce fastest under shorter wavelengths, specifically best at blue light. Any ideas for devices or materials that could help out would be appreciated! An idea I had was to use crystals, specifically Neodymium-doped yttrium orthovanadate, which can split an infrared wavelength in half and make it green (i think). I can use the material under the sun to turn all the higher wavelengths into lower to preserve the same light energy, but convert it into lower wavelengths. Issues: not sustainable, probably expensive. Any other similar ideas or ways I can improve on my idea? thanks!
Biology news on Phys.org
Welcome to PF.
Infrared is the low-energy end of the spectrum, ultraviolet is the high-energy end. You can down-convert UV to visible light, but not easily up-convert IR to visible.
Likes BillTre
metz said:
TL;DR Summary: reproduction, optics, wavelengths, light, sustainability, material, chemistry, earth sciences, microorganisms
hello!
Most commercial LEDs have a spike at 400nm. Do you have a radiometer you can borrow from the physics techs? If not you can check the technical spec sheet before you purchase and check the SPD. You will get low UV and dips in green and red but get your blue spike.
hello!
These are photosynthetic I take it? What species? @jim mcnamara and @BillTre for their reference.
Frequency doubling with nonlinear optics requires very high intensity to have a significant effect, much more than your samples will tolerate.
You should be able to convert UV to blue, by using a florescent material.
One problem will be directing the scattered light produced, so that it falls where you can use it.
Likes jim mcnamara
I think the simplest solution would be just purchase some batches of LEDs with the appropriate wavelengths (and a driver circuit, of course).
It's not a continuous spectrum, but cheap and stable.
Likes DaveE and hutchphd
Hi @metz. Out of curiosity, what is the size - e.g. Petri dish or large tank?
"They reproduce fastest under shorter wavelengths, specifically best at blue light."
can you share your data?
