Conts fncs, open sets, boundry
  • Thread starter Thread starter redyelloworange
    Sets
redyelloworange
Let U and V be open sets in Rn and let f be a one-to-one mapping from U onto V (so that there is an inverse mapping f-1). Suppose that f and f-1 are both continuous. Show that for any set S whose closure is contained in U we have f(bd(S)) = bd(f(S)).
Open sets: every point in the set is an interior point. int(S) = S. Or S contains none of its boundry points.
bd(S) = {x in Rn | B(r,x)∩S≠ø and B(r,x)∩Sc≠ø for every r>0}
ie, show that the function takes a boundry to a boundry.
Let S be a set in U. The let f(S) = T. Note that f-1(T) = S.
Also, since T = {x in Rn s.t. f(x) V} and f conts, and V open, then T is open.
The same conclusion holds for S.
Thus T and S are both open. They also have the same number of elements.
I don't know where to go from here.
Now state the definition of continuity in terms of balls. f(x)=y is continuous at x if for every B(y,d) there is a radius e such that f(B(x,e)) is contained in B(y,d).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
