Conundrum about meaning of "Dwell" and "Dwell Meter"
  • Thread starter jim hardy
  • Tags
    Meter
In summary: If your dwell meter does not have a voltage reading across the coil, connect a voltmeter to the leads and measure the voltage across the coil.This would give the correct indication.3) If the voltage measured across the coil is not correct, adjust the dwell angle by adjusting the set screw on the camshaft.This would give the correct indication.4) If the voltage measured across the coil is still not correct, the coil may require replacement.This would give the correct indication.
jim hardy
Dearly Missed
9,832
4,895
In the days of points everybody used a Dwell Meter to check their points gap setting.
Even this old PF thread is vague as to meaning of "dwell" as regards coil charge time.
https://www.physicsforums.com/threads/dwell-time.64011/
The original Kettering patent used term "dwell" in another sense, namely points closed when engine is stopped which would run down the battery.
https://www.google.com/patents/US1223180
The resistance coil 24, which may be in the shape illustrated or in any other form is preferably constructed of iron wire, nickel or other metals having a normally low coeflicient of resistance, but thereslstance of which will be increased as the heat or tem perature thereof increases, that is, one of the properties of metals of this character being that they are normally good electrical conductors for current, up to a certain predetermined point, but beyond that polnt, the resistance thereof, materially increases as the temperature of the metals are raised by mechanism has been brought to a stand-still in such position that the circuit is closed thcrethrough, or from other causes, a con tinuous flow of 'current will be set up through the main circuit. If this flow of current is permitted to exist, asis generally the case, in ignition systems now in use, the supply of current contained in the battery or accumulator 20, would be materially reduced within a short time.
He included a temperature sensitive iron wire to reduce coil current when points stay closed too long, sort of a 1912 PTC thermistor. It doubtless evolved to the ballast resistor we all knew and loved in the 1960's.
Nowadays "Dwell" is defined as fraction of the time points stay closed, ie coil charging time expressed as degrees of camshaft rotation.
https://www.collinsdictionary.com/us/dictionary/english/dwell-angle said:
( Automotive engineering : Vehicle components , Engine, transmission, and exhaust )
https://www.collinsdictionary.com/us/dictionary/english/dwell angle is the amount of time, measured as https://www.collinsdictionary.com/us/dictionary/english/degree of https://www.collinsdictionary.com/us/dictionary/english/rotation, that https://www.collinsdictionary.com/us/dictionary/english/contact breakers close in a https://www.collinsdictionary.com/us/dictionary/english/distributor.
A logical enough unit, but take a look at what a "Dwell Meter" reports !
It's just a voltmeter connected across the points EDIT Later i found this was a bad assumption on my part , read on..
points closed = no voltage
points open = battery voltage (12 volts)
so, more time the points are open = more voltage = increasing meter indication
0 volts = points always closed = coil energized 100% of the time
12 volts = points always open = coil energized 0% of the time
If full scale indication = battery voltage 12 volts = points always open, coil energized 0 % of the time
AND that agrees with the right hand end of the scale - a six lobe cam would be 60 degrees between lobes , meaning 60 degrees indicated dwell says points are open for the entire 60 degrees between cylinders and the engine ought not run because there's no time left to charge the coil between cylinders - the points never close.
so i think there's widespread confusion afoot.
I think a dwell meter reports not the number of camshaft degrees points are closed charging the coil,
instead it reports the number of camshsft degrees the points are open between charging intervals.
Despite what's written all over the internet.
EDIT Atleast some dwell meters report correctly, as i found in post further down. Next line is wrong,too .
Setting points for more dwell indication as indicated by a dwell meter will hurt high speed performance because it shortens coil charge time.
Next time you have your dwell meter out, put a 9 volt battery across it and see what it reads ?
I think it will read about ¾ scale, EDIT retracted, see further down
which is 45 degrees on 6 cylinder scale or 33.75 degrees on 4 oops make that 8 cylinder scale.
Then check carefully - does widening the point gap make your dwell meter read more dwell angle , or less ?
I think the scale on dwell angle meters is backward. I'd love to know where i went wrong.
EDIT
In one case i found a dwell meter with scale printed in reverse which corrects the error, a few posts down
I suspect most but not all read correctly. Also found two with active internal electronics to make them report correctly.
old jim
I don't know the answer @jim hardy, so I guess it is the "curmudgeon's conundrum." :wink:
Hmmm here's instructions for an ancient marine engine
http://www.moyermarine.com/faq/4.5.html
1) Connect the dwell meter as per its manufacturer's instructions: Generally one of two leads is connected to the positive terminal of the battery and the other lead to the negative terminal of the coil.
Note they measure voltage across the coil not across the points.
That would give the correct indication .
I'll check a dwell meter's instruction manual if i can find one online.
One needs to understand his test equipment in order to not get fooled by it.old jim
http://dalhems.com/f/d/ebc1a67544af4773b36ba484007bdcd2/cp7605.pdf
says measure voltage across points EDIT but i was unable to tell from his manual whether it reads dwell or dwell's complement..
from https://www.scribd.com/document/35604330/TACH-DWELL-Tester-Instructions
they got it wrong too.
EDIT I couldn't tell from this manual if it's right or wrong
This one gets it backward too
EDIT This one has the reverse printed scale so reads correctly
https://www.manualslib.com/manual/449419/Actron-612.html?page=2#manual
So far the Atomic 4 Marine engine guy looks like the clear winner
It's just something to be aware of.. If the proper setting for your car is midscale it won't matter which way you measure
but there's a LOT at least some wrong directions in circulation out there.
If you understand the measurement you can do it with just a voltmeter.
Doggone right I'm a curmudgeon. :wink: My hero is Uncle Hub of 'Secondhand Lions' .
old jim
https://www.google.com/patents/US1223180He included a temperature sensitive iron wire to reduce coil current when points stay closed too long, sort of a 1912 PTC thermistor. It doubtless evolved to the ballast resistor we all knew and loved in the 1960's.
This image is broken.
This one is broken, too.
This might be an oversimplification, because the points don't just go from closed to open and stay there. I'm not an expert in the internal workings of a dwell meter, but I have used them to set points in multiple cars.
I'm going to guess that the "dwell" that is being measured is the fraction of the maximum possible voltage that is attained before the points close again.
Again, it's been years since I used a dwell meter (it was on a Chevy V8). I don't remember the exact figure, but I think the dwell angle was about 30 degrees. The points cam would have had 8 lobes, at 45 degrees apart.
Here's a picture for a V6 engine.
It seems to come down to how you define "dwell," either as the time the points are open or that they are closed. If you know one, you can calculate the other easily. In the image above, if you set the dwell high (i.e., points closed longer), the time available to charge the coil is less.
old jim
BTW, I have two vehicles that came with points, both are motorcycles. One is a '46 HD WL (45 cu in motor, flathead), and the other is a '48 HD FL (74 cu in motor, OHV). The '48 is now running an electronic ignition, so no points, but the older one is still running points. I don't use a dwell meter on it - I set the timing statically, although I could set the timing on both using a strobe timing light.
I don't know what that means. I snipped and annotated it with Paint, then uploaded.
Perfect!
A dwell meter EDIT make that voltmeter connected across the points will report 28 degrees
A dwell voltmeter connected across the coil will report 32 degrees
and the engine will run pretty well throughout its normal speed range with either setting .
Agreed 2000 per cent.
From https://www.collinsdictionary.com/us/dictionary/english/dwell-angle
Definition of 'dwell angle'
Specialist English: dwell angle
Useful links
Comments
dwell angle in Automotive Engineering (dwɛl æŋgəl)
Word forms: (regular plural) dwell angles
noun
Unless dwell angle is accurate, ignition timing won't be accurate.
The period, measured in degree of cam rotation, during which the contact points remain closed is called the dwell angle.
The dwell angle is changed by moving the points closer to or away from the distributor cam.
Collins English Dictionary. Copyright © HarperCollins Publishers
That is the definition i find in every article, fraction of a firing cycle that points stay closed which is the time available for current to build up a strong magnetic field in the coil. They call that "Charging the coil" which to me sounds intuitive. You're building up energy in the coil that you'll discharge into the sparkplug when points open.
Hmm that comes down to how you define "charge the coil"
I call "charging the coil" that interval of time when points are closed allowing current to rise building up an intense magnetic field, the 32 degree "Dwell" in your image. When the points open that field collapses forcing spark current into the plug.
So for me, more dwell gives more charging time. But the instructions for the two dwell meters i found and linked tell one to connect his meter so it reads backward, reporting for your image ( 60 minus Dwell) degrees. Might call it "complement of dwell" or "Dwell's Complement" ..
Now i suppose it's possible there is collusion between manufacturers of vehicles and manufacturers of dwell angle meters , and the number we're told to adjust for is really "Dwell's Complement" .
Is there a GM design guy in the house ?
old jim
Here's a home-made dwell meter that properly reports closed time
note it requires a power source meaning either a three lead hookup or an internal battery.
http://www.qsl.net/kd7rem/dwellmtr.htm
The left hand 2N2222 'complements' the points open-closed status and reports it to the meter . So this one displays fraction of time points are closed not open.
Hmmmmm
here's an instruction manual for an old dwell meter that had an internal battery
http://www.liblbc.info/images/Sun/tdt_repair.pdf
Sun would do it right...
might be i need to revisit those other instruction books ? Will do.
It means that, for me at least, the image is not displaying. I see a small icon of a computer screen with an X across the screen.
Seeing all of the above, I'm glad I stuck to using the auto manufacturer's recommended point gap measurement and let the distributor cam profile determine the number of degrees of "dwell".
Likes jim hardy
Aha ! MY MISTAKE ! Look at the scale on this meter -
zero volts is 100% dwell(45 or 60 degrees) points never open and full voltage is 0% dwell points never close !
I must apologize for maligning that manufacturer - hereby tendered to Actron https://www.manualslib.com/manual/449419/Actron-612.html?page=4#manual
This manual that i also cited doesn't give enough detail to know how it works
so i owe that manufacturer an apology, and a chide for inadequate instruction book. Hereby tendered .
Likewise this manual doesn't give enough detail to know how it works.
So i owe him the same apology and chide. Hereby tendered , Actron again, http://dalhems.com/f/d/ebc1a67544af4773b36ba484007bdcd2/cp7605.pdf
Once again i am hoisted on my own petard .
Reminding me of my favorite saying, "When all else fails, read the instruction manual . "
a BIG serving for me -
Sigh ... this is how a fellow learns ! from his mistakes... my concept of "Dwell" is a lot clearer now.
will go back and fix earlier posts now
old jim
New
? I don't know what to say , they show for me both in my post and in your quote of it.
but I've seen that sometimes , for me it's just one of those vagaries of the e-wind .
Here's links for the two broken images
https://www.physicsforums.com/attachments/dwellmeterhookup-jpg.194652/
https://www.physicsforums.com/attachments/analogdwellmeter-jpg.194650/
This is far less reliable when you consider how the components can wear.
Lol... just kidding.[COLOR=#black]..[/COLOR] :olduhh:
Here are some links...
http://urcar-engine.blogspot.com/2011/11/dwell-angle.html...
Dwell and Timing Explained Even More...
And, krab had it right...
krab said:
The dwell time is the amount of time the ignition coil primary has current running through it.
Look at all the different definitions the word "dwell" can have, but it usually means... pause, delay, linger, reside, or stay.
Lol... get the point ?[COLOR=#black].[/COLOR] :oldbiggrin:
Likes jim hardy
Thanks Guys for your good natured indulgence. And the great images.
I'll still take apart my dwell meter (when i find it) to see how it handles " Dwell's Complement", that inverse relation between average volts across points and dwell .
So far I've seen that reversed scale on the Actron 612 and two with internal electronic inverting circuits.
OCR's links are spot on
as are Mark's comments.
I have a '79 Sportster with points and a kick-starter . Set it static too. With only two cylinders there's plenty of time available to charge the coil.
Your two antiques sound exquisite.!
old jim
Likes OCR
I've only ever used a dwell meter that was a function on a digital multimeter. The number of cylinders was a selectable setting, like resistance range might be.
I always imagined it would have a PLC in it that was measuring duty cycle and running a simple internal calculation: duty*360/#cylinders.
Never thought about how it would work on an analog meter.
Interesting thread. Thanks Jim.
Likes jim hardy and OCR
Hi Jim, please re-upload those images. Something went wonky with the original upload. Thanks!
Likes OCR
Warning, the majority of this post could definitely be considered "off subject" but just thinking about the issue revived many memories about dealing with the earlier ignition systems in competition applications.
The primary wearing component on the old standard ignition points was the composite material blade that ran against the distributor cam because wearing of this component affected both dwell and ignition timing. That is the reason that the checking and adjusting of the point gap was a part of the standard periodic maintenance program (as was checking and adjusting the valve stem and rocker arm gaps); in competition, verifying both of these and engine timing was included in every pre-race engine setup. As long as correct lubrication of the distributor cam was maintained wearing of the cam lobes that was the other possible source of a variance in dwell was of little concern.
In the early '60's when I was most involved in competition tuning, concern about point arc pitting and poor point contact were other primary concerns and resulted in both short term abrasive point cleaning and point set replacements. One of the frequently discussed items on higher rpm engines of the time were the issues of point inertia and "point bounce" vs point spring loading; but, point arc pitting pretty much trumped all other issues when it came to the life of a point set particularly when it came to the higher voltage "performance" coils that were available.
At the same time, all of my work was on 4 cylinder/4 cycle engines and that probably minimized the need for concerns about the precision of dwell setting.
Likes OCR and mic*
Reloaded both as jpg's from my local PF folder
if they're still wonky please advise and i'll re-"Paint" them
And-
SORRY for the false direction i started early in the thread
it stemmed from a long time misconception I've held that "Dwell" is the amount of time points dwell open not closed .
Glad to know "where i went wrong" all those years ago. Maybe it'll help others understand their dwell meter.
"It's not what we don't know that hurts us, it's what we know that ain't so."
old jim
Likes OCR
Related to Conundrum about meaning of "Dwell" and "Dwell Meter"
What is the meaning of "dwell" and "dwell meter"?
"Dwell" refers to the amount of time that a spark plug remains in contact with the distributor's contact points in a vehicle's ignition system. A "dwell meter" is a tool used to measure this time.
What is the purpose of measuring dwell in a vehicle's ignition system?
The dwell time directly affects the amount of energy transferred to the spark plugs, which in turn affects the engine's performance. By measuring dwell, mechanics can ensure the correct amount of energy is being delivered to the spark plugs, resulting in proper engine functioning.
How is dwell measured using a dwell meter?
A dwell meter is connected to the vehicle's ignition system and measures the time in degrees that the distributor's contact points are closed. This reading is then compared to the manufacturer's recommended dwell time for the specific vehicle.
Why is it important to maintain the correct dwell time in a vehicle's ignition system?
If the dwell time is too short, the spark plugs may not receive enough energy, resulting in weak sparks and poor engine performance. If the dwell time is too long, the distributor's contact points can wear out more quickly and cause damage to the ignition system.
What are some common symptoms of incorrect dwell time in a vehicle's ignition system?
Some signs of an incorrect dwell time include difficulty starting the engine, misfiring, and poor fuel economy. Over time, incorrect dwell time can also cause damage to the spark plugs and other components of the ignition system.
  • Mechanical Engineering
  • Electrical Engineering
