styleworker
- 4
I'm studying the effect of a magnetic field on a non-conducting fluid, such as liquid oxygen or liquid hydrogen. As I know a convective flow can be driven, if the extern magnetic field is strong enough. The extern magnetic field can be uniform or nonuniform, but the effect of convection is much greater, if there is a extern magnetic gradient acting on the fluid.
My model is 5L spherical enclosure which is filled with liquid oxygen. The enclosure is heated from below and cooled from above, so that the heat is only transferred by conduction. Both temperatures are kept below the boiling temperature. In the center of the enclosure is a magnetic source, which has to be defined.
Know I want to find a suitable magnetic source to produce the suitable magnetic field, which drives the convection. The magnetic source should be compact and leight weighted.
A idea is to take a magnetic coil, such as the Helmholtz-Coil, but this source would probably not drive the convection, because of its constant magnetic field inside the coil.
Because of fluid's temperature at about 80K it's possible to use superconductors. For example the YBCO superconductor can reach a magnetic flux density of 0.8 - 1.1 T.
Are there any other possibilies?
