I Conventional description of the matter wave
George444fg
TL;DR Summary
I have been working on a relatively simple problem. Just take a quantum wave function for which a physical requirement is that an arbitrary displacement of x or an arbitrary shift of t should not alter the character of the wave, and I want to find the state function solution. A possible guess that works is sin(kx-wt)+acos(kx-wt). I found out that a=±i, and then I have to say which one corresponds to the convention. I said that it must be that γγ=i, because if it was -i, then the time derivative of the state function would have been negative, and using Schrodinger equation that would imply negative energy states. Am I right?
Yes, you are correct. The convention that is usually used is that the wave function should have a positive energy, and so the time derivative of the wave function should be positive. Therefore, the coefficient of the cosine term must be +i in order for the wave function to satisfy this requirement.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
