Conventional renormalization to order in the coupling or loops?
In summary, conventional renormalization involves computing a scattering amplitude in terms of bare quantities and then replacing these with physical quantities to make the amplitude finite. When computing the amplitude to a certain order, one should also compute the bare quantities to the same order to ensure consistency. This works due to the graph theoretic structure of Feynman integrals, and can be further explained using Zimmerman's Forest formula.
center o bass
560
In conventional renormalization one is first supposed to compute a scattering amplitude of interest in terms of bare quantities ##\lambda_0, m_0...##, then compute these bare quantities in terms of physical quantities, i.e. ##m(m_0,\lambda_0,...), \lambda(m_0, \lambda_0,...)## and substitute these back into the scattering amplitude. The amplitude should now be finite.
That is all nice, but suppose one computes the scattering amplitude to ##O(\lambda_0^2 )## and to first order in loops. To be consistent, should one now compute the mass and coupling to second order in the coupling or first order in loop corrections?
And why?
At each order in perturbation theory you make the bare/physical replacement to the order previously computed. These should leave diveregences at the current order that can be absorbed by invoking the renormalization conditions.
It works because of the graph theoretic structure of Feynman integrals. Look for explanations of Zimmerman's Forest formula.
Part 1 of these lecture notes gives an nice intro and some references: https://arxiv.org/abs/1004.3462
Related to Conventional renormalization to order in the coupling or loops?
1. What is conventional renormalization?
Conventional renormalization is a mathematical technique used in quantum field theory to remove the infinities that arise in calculations involving particles and fields. It involves adjusting the parameters of a theory to account for these infinities and make the results physically meaningful.
2. What is meant by "order in the coupling" in renormalization?
The "order in the coupling" refers to the strength of the interaction between particles. In renormalization, calculations are typically done to a certain order in the coupling, meaning that only interactions of a certain strength are considered. Higher orders in the coupling can be included to improve the accuracy of the calculations.
3. What does it mean to renormalize to a certain order in loops?
Renormalization to a certain order in loops means that calculations are done to a certain level of precision by including a certain number of loop diagrams. These diagrams represent virtual particles that contribute to the interactions between particles. Including higher orders in loops can improve the accuracy of the results.
4. How does conventional renormalization help solve the problem of infinities in quantum field theory?
Conventional renormalization helps solve the problem of infinities in quantum field theory by adjusting the parameters of a theory to account for these infinities. By doing this, the infinities are absorbed into the parameters and the calculations become finite and physically meaningful.
5. Can conventional renormalization be applied to all quantum field theories?
Conventional renormalization can be applied to most quantum field theories, but there are some theories where it does not work. In these cases, other renormalization techniques may be used to remove infinities and make calculations meaningful.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
