Convergence and Divergence with Series
In summary, the first series \sum^{\infty}_{n = 1} \frac{n - 1}{3n - 1} is divergent because \lim a_n=\frac{1}{3}\neq 0, while the second series \sum^{\infty}_{n = 1} \frac{1 + 2^n}{3^n} converges to \frac52 since r < 1.
shamieh
539
Determine whether the series is convergent or divergent.
\(\displaystyle \sum^{\infty}_{n = 1} \frac{n - 1}{3n - 1}\)
I ended up with \(\displaystyle \frac{1}{3} * 1 = \frac{1}{3}\) , which is 0.333 ... so wouldn't that mean that \(\displaystyle r < 1\)? Also wouldn't that mean that it is convergent since \(\displaystyle r < 1\) ?
I don't understand why this is actually divergent?Also,
\(\displaystyle \sum^{\infty}_{n = 1} \frac{1 + 2^n}{3^n}\)
I split this up into two summations
Ended up with \(\displaystyle \frac{5}{2}\) and r < 1, so this converges at \(\displaystyle \frac{1}{3}\) while approaching infinity right?
Re: Convergene and Divergence with Series
For \(\displaystyle \sum^{\infty}_{n = 1} \frac{n - 1}{3n - 1}\),
\(\displaystyle \lim a_n=\frac{1}{3}\neq 0\)
So, the series diverges by the divergence test.
\(\displaystyle \sum^{\infty}_{n = 1} \frac{1 + 2^n}{3^n}\) converges to \(\displaystyle \frac52\).
FAQ: Convergence and Divergence with Series
What is the difference between convergence and divergence with series?
Convergence and divergence refer to the behavior of a series, which is an infinite sum of terms. A convergent series is one in which the terms approach a finite limit as the number of terms increases, while a divergent series is one in which the terms either approach infinity or do not approach a specific limit.
How can I determine if a series is convergent or divergent?
There are several tests that can be used to determine convergence or divergence of a series, such as the ratio test, the root test, and the comparison test. These tests involve evaluating the behavior of the terms in the series and can help determine if the series will converge or diverge.
What is the significance of convergence and divergence in mathematics?
Convergence and divergence play a crucial role in mathematical analysis and calculus. Knowing whether a series is convergent or divergent can help determine the behavior of a function and its derivatives, and can also be used to solve various mathematical problems and equations.
Can a series be both convergent and divergent?
No, a series can only be either convergent or divergent. If a series is convergent, it cannot also be divergent and vice versa. However, some series may be neither convergent nor divergent, in which case they are said to be oscillatory.
Is there a visual representation of convergence and divergence?
Yes, there are graphical representations of convergence and divergence, such as the graph of a convergent series approaching a horizontal asymptote or the graph of a divergent series increasing or decreasing without bound. These visual representations can help illustrate the concept of convergence and divergence in a more intuitive way.
