MHB Convergence as for the cofinite topology on R
The cofinite topology on R defines open sets as either the empty set or sets with finite complements. In this topology, the sequence \( x_n = \frac{1}{n} \) converges to 0 because any open neighborhood of 0 must contain all but a finite number of terms from the sequence. The definition of convergence in this context requires that for every open neighborhood \( U \) of the limit, almost all terms of the sequence must lie within \( U \). It is established that the sequence does not converge to any number other than 0, as any neighborhood around a different point would exclude infinitely many terms from the sequence. Thus, the conclusion is that \( x_n \) converges to 0 in the cofinite topology on R.
mathmari
MHB
Hey! :giggle:
Does the sequence $x_n=\frac{1}{n}$ converges as for the cofinite topology on $\mathbb{R}$ ? If it converges,where does it converge? Could you explain to me what exactly is meant by "cofinite topology on $\mathbb{R}$" ? Do we have to define first this set and then check if we have convergence inside that set? :unsure:
Hey mathmari!
Wiki defines cofinite topology here.
It's the topology where every open set must either be the empty set, or it must have a finite complement. 🤔
Additionally we need the definition for convergence in a topology. We cannot use the usual $\varepsilon-\delta$ method, since distances are not defined in a topology.
Can we find that definition? 🤔
Do we use the following definition?
$\langle x_n:n\in\mathbb{N}\rangle$ converges to $x$ if and only if for each openneighborhood $U$ of $x$ there is an $m\in\mathbb{N}$ such that $x_n\in U$ whenever $n\ge m_U$.
:unsure:
Yep. (Nod)
Yep. (Nod)
In general it holds that $\frac{1}{n}\rightarrow -$, so do we have to check if for each open neighborhood $U$ of $0$ there is an $m\in \mathbb{N}$ such that $\frac{1}{n}\in U$ whenever $n\geq m_U$ ?
Or do we apply the definition in practice? :unsure:
Yep. (Nod)
What does an open neighborhood of $0$ look like? 🤔
Is it a ball with center the originand radius $\epsilon>0$ ? :unsure:
Nope. (Shake)
We can only have a ball with a radius if we can measure distances. But in a topology those are not defined. Instead a neighborhood of a point is a subset that contains an open set - according to the topology. And moreover that open subset must contain the point. 🧐
Which open subsets are in the topology that contain 0? 🤔
Nope. (Shake)
So do we consider an interval around $0$ ? :unsure:
No, we have to apply the definition of a cofinite topology.
It says that the open subsets are the empty set plus all subsets that have a complement that is finite. 🤔
Btw, after we've established what a neighborhood of $0$ is in the cofinite topology, we will look at an interval around $0$ that is inside the neighborhood. 🤔
Is it an open set that contains an open subset containing 0? :unsure:
More precisely, it's a subset $V$ of $\mathbb R$ that includes an open set $U$ containing $0$.
Note that $V$ is not necessarily open.
$$0 \in U \subseteq V \subseteq \mathbb R$$
Now what was an open set in the cofinite topology of $\mathbb R$ again? 🤔
It is a set that has finite complement or is empty, right? :unsure:
Let $X$ be an arbitrary set. The non-empty open nsets are the complements offinite sets. We have to define also the empty set.
A sequence $x_n \to x$ converges as for the cofinite topology iff for each open neighbourhood $U$ of $x$, $U = X \setminus \{s\}$ for a $s$ with $x \neq s$, it holds that almost all $x_n$ are in $U$. So if $x \neq s$, thenalmost all $x_n \neq s$. If infinitelymany $x_n=s$ then $x=s$.
So in this case:
Let $U$ be an open neighbourhood of $0$. Since $\Bbb R\setminus U$ must be finite, $U$ containsallbut a fininte numberof terms of the sequence. Therefore $x_n\rightarrow 0$.
Is that correct? :unsure:
mathmari said:
Let $U$ be an open neighbourhood of $0$. Since $\Bbb R\setminus U$ must be finite, $U$ contains all but a finite number of terms of the sequence. Therefore $x_n\rightarrow 0$.
Is that correct?
Looks right to me. (Nod)
So we conclude that $0$ is a limit of the sequence.
Is it 'the' limit? Can we tell for instance whether the sequence converges to $1$? (Wondering)
The limit is all the numbers of the form $\frac{1}{n}$ with $n\in \mathbb{N}$, right? :unsure:
Suppose we pick a number that is not of that form. Let's say we pick $\pi$.
Then an open neighborhood $U$ of $\pi$ is all of $\mathbb R$ except for a finite number of points, and it must include $\pi$ itself.
The neighborhood $U$ will contain all but a finite number of the sequence won't it? 🤔
  • · Replies 17 ·
  • · Replies 61 ·
  • · Replies 21 ·
