Convergence Condition for Applying Ratio Test to Power Series
In summary, the ratio test can be applied to a power series if the series of absolute values is bounded both above and below by the series of absolute values and the negative of the series of absolute values. Other tests may also be applicable, but the ratio test is always a valid option.
alexmahone
304
Given a power series, what is the condition on its coefficients that means the ratio test can be applied?
I think it can always be applied. Other test just may be easier for a given power series.
You actually should always do the ratio test on the series of ABSOLUTE VALUES, to prove absolute convergence (i.e. to show the series is bounded both above and below by the series of absolute values and the negative of the series of absolute values).
FAQ: Convergence Condition for Applying Ratio Test to Power Series
What is the ratio test for power series?
The ratio test is a method used to determine the convergence or divergence of a power series. It involves taking the limit of the absolute value of the ratio of consecutive terms in the series. If this limit is less than 1, the series is convergent. If it is greater than 1, the series is divergent. If the limit is exactly 1, the test is inconclusive and another method must be used.
When is the ratio test used?
The ratio test is typically used when the terms of a power series do not have a clear pattern or when other tests, such as the comparison test, do not apply. It is also useful for determining the radius of convergence of a power series.
How do you apply the ratio test to a power series?
To apply the ratio test, you first take the absolute value of the ratio of consecutive terms in the series. Then, take the limit of this value as n approaches infinity. If the limit is less than 1, the series is convergent. If it is greater than 1, the series is divergent. If the limit is exactly 1, the test is inconclusive and another method must be used.
What is the difference between the ratio test and the root test?
The ratio test and the root test are both methods used to determine the convergence or divergence of a series. The main difference between them is that the ratio test compares consecutive terms in the series, while the root test takes the nth root of the absolute value of each term. Additionally, the ratio test can be used to determine the radius of convergence, while the root test cannot.
Can the ratio test be used for all power series?
No, the ratio test can only be used for power series with non-negative terms. If the terms in the series have a clear pattern or the series is a geometric series, other tests such as the divergence test or the geometric series test should be used instead.
