Eclair_de_XII
- 1,083
- 91
- TL;DR Summary
- Consider a sequence ##a_n## and for each ##n##, define:
##\alpha_n=\frac{1}{n}\sum_{i=1}^n a_i##
Prove that if ##a_n## converges to ##A##, then ##\alpha_n## converges to ##A##.
Let ##\epsilon>0##. Then there is an integer ##N>0## with the property that for any integer ##n\geq N##, ##|a_n-A|<\epsilon##, where ##A\in\mathbb{R}##.
If for all positive integers ##n##, it is the case that ##|a_n-A|<\epsilon##, then the following must hold:
\begin{eqnarray}
|\frac{1}{n}(a_1+\cdots+a_n)-A|&=&|\frac{1}{n}(a_1+\cdots+a_n)-\frac{1}{n}(A+\cdots+A)|\\
&\leq&\frac{1}{n}\sum_{i=1}^n|a_i-A|\\
&<&\frac{1}{n}\sum_{i=1}^n\epsilon\\
&=&\frac{1}{n}(n\epsilon)\\
&=&\epsilon
\end{eqnarray}
Now assume that this is not the case. Then there exists a finite set of integers ##I## s.t. if ##i\in I##, then ##|a_i-A|>|a_N-A|##. Denote ##M=\max\{|a_i-A|:i\in I\}##.
We prove that ##2\alpha_n## converges to ##2A##. Choose the integer ##N'## with the property that ##N'\geq\frac{M\cdot |I|}{\epsilon}##. Then whenever ##n\geq N'##:
\begin{eqnarray}
|\frac{1}{n}(a_1+\cdots+a_n)-\frac{1}{n}(A+\cdots+A)|&\leq&\frac{1}{n}\sum_{i=1}^n|a_i-A|\\
&=&\frac{1}{n}\sum_{i\in I} |a_i-A|+\frac{1}{n}\sum_{j\notin I}|a_j-A|\\
&<&\frac{|I|\cdot M}{N'}+\frac{1}{n}(n-|I|)\epsilon\\
&<&\epsilon+\epsilon
\end{eqnarray}
Since ##2\alpha_n## converges to ##2A##, it must be the case that ##\alpha_n## converges to ##A##.
\begin{eqnarray}
&=&\epsilon
\end{eqnarray}
\begin{eqnarray}
\end{eqnarray}
