Convergence of an Infinite series and a related Qn
In summary, the conversation discusses the convergence of different infinite series, including \sum_{x=1}^{\infty}\frac{1}{x}, \sum_{x=1}^{\infty}\frac{1}{x^{2}}, and \sum_{x=1}^{\infty}\left(\frac{1}{x^{\left(1+epsilon\right)}}\right). The conversation also mentions using induction and the ratio test to prove convergence, as well as the use of the integral test for convergence. The idea of using the Riemann Zeta function to prove convergence is also mentioned.
bincy
38
Dear friends,
\(\displaystyle \sum_{x=1}^{\infty}\frac{1}{x}\) diverges.
But \(\displaystyle \sum_{x=1}^{\infty}\frac{1}{x^{2}}=\frac{\pi^{2}}{6}\)
How can we prove that \(\displaystyle \sum_{x=1}^{\infty}\left(\frac{1}{x^{\left(1+epsilon\right)}}\right)\) converges to a finite value?
Thanks in advance.
Bincy.
I preface every post like this that I could very well be wrong, but here is my take on it before someone else can confirm/deny my reasoning or provide a different proof.
If epsilon is an integer then I think induction can prove this.
1) Looking at \(\displaystyle \frac{1}{x^n}\) you know it converges for n=2. I suppose your question is looking at \(\displaystyle \frac{1}{x^{n+1}}\), so n=1 is true.
2) Using the ratio test, you can show that if n converges that implies that (n+1) converges.
I agree whatever you said. But there is a small catch.By epsilon, I meant that a very small real no. like 10^-10. For n>=2, we can prove the convergence of the series. But what about 1<n<2 ? If we can prove the convergence for n=1+ (1+ means epsilon greater than 1), any infinite series of this kind converges for n>1.
I think you can use the integral test for convergence.
Interestingly Wikipedia uses the OP's problem as an example of the integral test.
I believe there is a nice proof in Lang's Complex Analysis of the Riemann Zeta Function. If not, I have a proof from Foote.
FAQ: Convergence of an Infinite series and a related Qn
What is the definition of convergence for an infinite series?
Convergence of an infinite series is when the sum of all the terms in the series approaches a finite value as the number of terms approaches infinity. In other words, the series has a well-defined limit or the sum of the series exists.
How do you determine if an infinite series is convergent or divergent?
There are several methods for determining convergence or divergence of an infinite series, such as the comparison test, the ratio test, and the integral test. These tests involve analyzing the behavior of the terms in the series and comparing them to known convergent or divergent series.
What is the significance of the limit comparison test in determining convergence?
The limit comparison test is a method for determining the convergence of a series by comparing it to a known convergent or divergent series. It can be helpful in cases where other tests are inconclusive or difficult to apply. However, it should be used with caution as it does not always provide a definitive answer.
Can an infinite series be conditionally convergent?
Yes, an infinite series can be conditionally convergent, which means that it is convergent but not absolutely convergent. This means that the series converges, but not if the terms are rearranged. This is in contrast to an absolutely convergent series, where the rearrangement of terms does not affect the convergence.
What is the relationship between the convergence of an infinite series and its related sequence?
The convergence of an infinite series is closely related to the convergence of its related sequence. If the terms in the series do not approach zero, then the series cannot converge. However, if the terms do approach zero, the series may still converge or diverge depending on the behavior of the terms. In general, if the series converges, then the related sequence must also converge, but the converse is not always true.
