alexmahone
- 304
Does the following series converge?
$\displaystyle\sum\frac{n^5}{2^n}$
fawaz said:Well what tests did you try?the ratio test and the root test both give you what you need. Try them. If you need more hints let us know.Mohammad
The formula for the convergence of $\displaystyle\sum\frac{n^5}{2^n}$ is given by the ratio test, where the limit as n approaches infinity of the absolute value of the ratio of the (n+1)th term to the nth term must be less than 1 for the series to converge.
The rate of convergence for $\displaystyle\sum\frac{n^5}{2^n}$ is geometric, meaning that the terms decrease in size at a constant ratio. This ratio is given by 1/2, as seen in the denominator of the series.
The value of the convergence for $\displaystyle\sum\frac{n^5}{2^n}$ represents the sum of an infinite series, which can be used in various mathematical and scientific calculations. It also helps determine the behavior of the series and whether or not it will approach a finite limit or diverge.
The convergence of $\displaystyle\sum\frac{n^5}{2^n}$ is relatively slow compared to other series with different terms. This can be seen by comparing the rate of convergence, as well as the value of the convergence, to other series. However, it is still a convergent series and can be useful in certain applications.
The convergence of $\displaystyle\sum\frac{n^5}{2^n}$ has various applications in fields such as physics, engineering, and computer science. It can be used to model the growth of populations, the decay of radioactive materials, and the convergence of numerical algorithms, among others.
