MHB Convergence of iteration method - Relation between norm and eigenvalue
The discussion focuses on the convergence of iteration methods using the iteration matrix G, emphasizing that the spectral radius, ρ(G), must be less than 1 for convergence, regardless of the norms of G. It is clarified that even if the norm of G exceeds 1, the powers of G can still converge as long as ρ(G) is less than 1. Additionally, for a symmetric matrix A, if the norm is 0.01, there exists an eigenvalue with an absolute value equal to 0.01, as the spectral radius is equal to the norm in this case. The relationship between the spectral radius and the norms is reinforced, highlighting its significance in determining convergence. Understanding these properties is crucial for analyzing iteration methods and eigenvalue behavior.
mathmari
MHB
Hey! :o
Let $G$ be the iteration matrix of an iteration method. So that the iteration method converges is the only condition that the spectral radius id less than $1$, $\rho (G)<1$, no matter what holds for the norms of $G$ ?
I mean if it holds that $\|G\|_{\infty}=3$ and $\rho (G)=0.3<1$ or $\|G\|_{1}=1$ and $\rho (G)=0.1<1$ in these both cases the iteration method converges, or not? (Wondering)
I have also an other question. Let $A$ be a symmetric matrix. If $\|A\|=0.01$ then there is an eigenvalue $\lambda$ with $|\lambda|\leq 0.01$, isn't it? We get that using the spectral radius: $\rho (A)=\max |\lambda_i|\leq \|A\|_1$, right? (Wondering)
Mathematics news on Phys.org
For an iteration procedure, you are going to be interested in powers of $G$. So what matters is that $\|G^n\| < 1$ when $n$ is large. It doesn't matter whether $G$ itself has norm larger than $1$, so long as the powers of $G$ have smaller norms.
The spectral radius has the property that $$\rho(G) = \lim_{n\to\infty}\|G^n\|^{1/n}.$$ So if $\rho(G)<1$ then $\|G^n\|<1$ whenever $n$ is large enough, and that is sufficient to ensure that the iteration method converges.
For a symmetric matrix, the spectral radius is equal to the norm. So if $\|A\|=0.01$ then there is actually an eigenvalue $\lambda$ with $|\lambda| = 0.01$.
The spectral radius has the property that $$\rho(G) = \lim_{n\to\infty}\|G^n\|^{1/n}.$$ So if $\rho(G)<1$ then $\|G^n\|<1$ whenever $n$ is large enough, and that is sufficient to ensure that the iteration method converges.For a symmetric matrix, the spectral radius is equal to the norm. So if $\|A\|=0.01$ then there is actually an eigenvalue $\lambda$ with $|\lambda| = 0.01$.
I see! Thank you very much! (Smile)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
