Convergence of oscillatory/geometric series
In summary, the conversation discusses determining for which values of r the series converges and provides a solution for various cases, including when r is between 0 and 1, when r is 1 or -1, and when r is greater than or less than 1. It is concluded that the series diverges in some cases and converges absolutely in others.
Mr Davis 97
1,462
44
Determine for which ##r\not = 0## the series ##\displaystyle {\sum_{n=1}^\infty(2+\sin(\frac{n\pi}{3})) r^n}## converges.
We have to split this up by cases based on ##r##.
1) Suppose that ##0<|r|<1##. Then ##|(2+\sin(\frac{2\pi}{3}))r^n| \le |3r^n|##. But ##0<|r|<1##, so the series ##\sum_{n=1}^{\infty}3r^n## converges. By the direct comparison test, the series ##{\sum_{n=1}^\infty(2+\sin(\frac{n\pi}{3})) r^n}## converges absolutely.
2) Suppose that ##r=1##. Then ##a_n = 2+\sin(\frac{2\pi}{3})##. This sequence oscillates, so does not converge to 0. Hence the series diverges.
3) Suppose that ##r=-1##. Then let ##a_n = (-1)^n(2+\sin(\frac{n\pi}{3}))##. This sequence oscillates, so does not converge to 0. Hence the series diverges.
4) Suppose that ##r>1##. Consider the subsequence ##a_{6k-5} = (2+\frac{\sqrt{3}}{2})r^n##. For this subsequence ##\lim_{k\to\infty}a_{6k-5} = +\infty##. Hence ##\lim_{n\to\infty}a_n \not = 0##. So the series diverges.
5) Suppose that ##r<-1##. Let ##p=-r##. Then ##a_n=(-1)^n(2+\sin(\frac{2\pi}{3}))p^n##. Consider the subsequence ##a_{6k-5} = (-1)^n(2+\frac{\sqrt{3}}{2})p^n##. The limit of this sequence does not exist, because it oscillates to positive and negative infinity. Hence ##\lim_{n\to\infty}a_n \not = 0##. Hence the series diverges.
Hello mr Davis,
Any reason for this posting ? PF isn't really meant for stamp-approving homework :rolleyes: . So: where's the doubt ?
Related to Convergence of oscillatory/geometric series
What is the definition of convergence in an oscillatory series?
Convergence in an oscillatory series refers to the behavior of the series as the number of terms increases towards infinity. A series is said to converge if the sum of its terms approaches a finite value as the number of terms increases.
How is convergence tested in an oscillatory series?
The most common test for convergence in an oscillatory series is the Ratio Test, which compares the ratio of consecutive terms in the series to a limit value. If the limit is less than 1, the series is said to converge. Another test is the Root Test, which compares the nth root of the absolute value of each term to a limit value.
What is the difference between absolute and conditional convergence in a geometric series?
Absolute convergence in a geometric series occurs when the sum of the absolute values of the terms converges, while conditional convergence occurs when the actual sum of the terms converges. In other words, absolute convergence takes into account the magnitude of the terms, while conditional convergence only looks at the values of the terms.
Can an oscillatory series converge to a value other than 0?
Yes, an oscillatory series can converge to any finite value other than 0. This is because convergence in an oscillatory series is not dependent on the behavior of the terms approaching 0, but rather on the behavior of the sum of the terms as the number of terms increases towards infinity.
How does the rate of convergence impact an oscillatory series?
The rate of convergence in an oscillatory series refers to how quickly the series approaches its limiting value. A series with a faster rate of convergence will reach its limiting value in fewer terms compared to a series with a slower rate of convergence. In general, a faster rate of convergence is considered more desirable.
